[GA] 1991 rs project $1550
Car: 1991 rs, 1985 z28
Engine: 3.1 v6, 305 tpi
Transmission: 700r4, 700r4
Axle/Gears: 3.23, 3.23
This is a 91 camaro rs with the 3.1 v6. It is a project car that needs work but does run. I bought a used 3.1 from another 91 and put new gaskets above the heads and installed it . That engine has around 88,000 miles on it and runs great. Also installed new radiator when i put the engine in. The car is almost complete only missing a couple interior pieces like switches and trim. The core support was damaged some from a previous accident so i took the front end apart and shot some primer to keep rust down from the chipped paint. Front end is on but needs to be bolted in place. I also installed a new fuel pump but po did the common hack job above the tank.
Needs: brake work, tires, exhaust ran from catback(I installed a new y-pipe), battery, and i would put a new fuel sending unit because gauge does not read right and car sat for years before i bought it. $1550
speedworks101
Mid-West Region
31
12-03-2004 12:59 AM
JMatlock88
01-20-2003 04:01 PM
