Post radio Replacement
Old Aug 22, 2002 | 09:36 AM
fulci1's Avatar
Hello!
I have a 85 Berlinetta with the digital dash and post radio. I NEED at least a cd headunit. Anybody there with some excellent suggestions on how to remove this radio and put in a GM standard or aftermarket (I like Pioneer) head unit. I can't even tell if the post radio works, as the wires to the antenna were cut (it looks like the antenna has been out of commission for a while).
Thanks!
Joe
Old Aug 22, 2002 | 09:57 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Here you go -----
I always recommend leaving the Berlinetta radio's in place to keep the uniqueness of the car intact....... Just install a CD changer in the hatch well !!!
*** If you decide to get rid of the radio - let me know.
Here is a picture of an aftermarket head-unit installation......
This thing is just a normal aftermarket housing used for adding an EQ or CD system to a "Regular" car. In This case - It has been turned upside down and mounted on the berlinetta center console once the factory head unit was removed.
Stores like Best Buy usually carry these things.
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
