Changing Load with 1 sub
Old Jun 26, 2003 | 02:58 PM
MrNova's Avatar
If I buy a mono amp, like an MTX 421D, and I use it to run a single 4 ohm sub, is there a way I can increase the load on the amp to 2 ohms so that I can pump more power to the sub?
Old Jun 26, 2003 | 03:08 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Not unless it’s a dual voice coil sub.
Old Jul 11, 2003 | 04:58 PM
MrNova's Avatar
So if I have an alpine type R which is a dual voice coil, how do I run the wires so that it will draw power from the amp at 2 ohms instead of 4 ohms.
EDIT: Nevermind, figured it out. Positive to positive to positive. Negative to negative to negative.
theshackle
Sep 17, 2020 08:26 AM
Infested
May 22, 2018 11:56 PM
z28addict8490
Sep 5, 2015 03:56 PM
1992Vortec
Aug 31, 2015 08:05 PM
jbd1969
Aug 17, 2015 07:06 PM
