Wire
Old Sep 24, 2003 | 11:15 AM
Yak's Avatar
Yak
Wire
ok I don't know much about car audio, i want to put a system in my car, I will be using 2 type R 12inch subs, and will have an upgrated reciever, a huge amp, and aftermarket speakers to replace the stock ones. What type (gauge) wire should i use? and will i need a second battery or a larger alternator?
Old Sep 24, 2003 | 03:46 PM
learsieglerZ'83's Avatar
Car: 1983 Z28
Transmission: 5 speed
well i guess it all depends on how big your HUGE amp is going to be. hows the stats on the amp you have?
Old Sep 25, 2003 | 02:57 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
If you're just running one amp you should be fine with 4ga. You won't need an amp that requires any more than that. Your stock alternator and single battery should also be fine. If you notice serious headlight dimming then think about installing a cap or a second battery.
Old Sep 30, 2003 | 01:15 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
u can use 18 gauge for your 6 x 9's n etc.
how big of an amp are you getting?
Old Oct 7, 2003 | 03:26 PM
shookumz11's Avatar
wire
8 awg is good for 500 watts
4 awg = 800
2 awg = 1500
single ott (1-0 awg) 2000+ but no third gen needs that.
Brian
Old Oct 8, 2003 | 05:45 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yak, depends on who makes the amp. If you were going to buy a Pyramid 1000 watt amp, I'd say to use 8 gauge. If you were going to buy a Rockford Fosgate 120 watt amp, I'd say to use 8 gauge.
Also, you might want to rethink your system. If you're putting in an aftermarket deck and new speakers, what will your huge amplifier power? Just the subwoofers? If so, if you get a huge amp to power your subs, you're going to have more bass then you should. The system will sound "dull" and lifeless, because the radio won't be able to power the normal speakers up enough- and when it tries, the radio will blast distortion thru those speakers, and rip them to shreds. Power doesn't kill, distortion does. (Which is precisely why a Pyramid 1000 watt amp will kill your speakers- distortion). You want a balance of power between the subs and normal speakers.
If a sales guy sold you that system, he'll be hoping that you'll come back in a month, telling him that you need to add a second amplifier for your inside speakers.
So what all this comes down to is- you might not want a huge amp to power two 12" subs. You might want a smaller amp to power one 10" sub. Two 12" subs might look cool, but I've heard systems with one 10" sub that blow most dual-12-sub systems away.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
