Bench testing amps, simulate signal wire?
Old Nov 11, 2003 | 10:44 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I'd like to test some amps, without taking mine out of my car and putting these in. I have a power supply, but I'm clueless as to how to get the amp to turn on. I know that there is a signal wire that I have hooked up to my power antenna lead on the radio, and I've also rigged it up under the radio fuse on the fuse black before.
What can I hook up to this to get the amp to tun on?
Old Nov 11, 2003 | 05:17 PM
onebadwagon's Avatar
it is called a "remote" wire, just run it from the positive side of your power supply.
adam
Old Nov 11, 2003 | 08:03 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
like he said, all that is is a relay for the high current power. A small loop wire from the battery to the remote terminal will do the trick.
use a discman with a 3.5mm to stereo RCA cable for an input signal....keep the gain low, until you get the sound or voltage you need!
Old Nov 11, 2003 | 10:12 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Straight from the 12v + to the wire? I didn't think it could be that easy
Old Nov 19, 2003 | 09:12 AM
87 GTA TPI's Avatar
Car: 1987 Pontiac Trans am GTA
Engine: 5.0L
Transmission: Dead 700r4
v
RazorN8
Jan 7, 2022 11:44 AM
Caspar
Jun 19, 2016 11:19 PM
mustangman65_79
Car Audio
Sep 8, 2015 08:20 PM
ZsTransAm
Aug 11, 2015 07:30 PM
