mounting detachable face in remote location?
Old 08-03-2010, 06:38 PM
siduramaxde's Avatar
Car: 86 berlinetta
Engine: 383
Transmission: built 700r4
Axle/Gears: 3.42 zexel torsen
I have a Berlinetta and if you have ever seen the stock HU you know how hard it would be to replace with an aftermarket HU. I want to keep the stock HU in place and then mount an aftermarket HU in the spare tire well. Then using a couple CAT5 cables solder the wire between the HU and the detachable face plate. The face plate will be mounted using double sided tape in a spot that is easily reached by the driver. Has anyone else done anything like this? Is there any brand that this would be easier with?
Old 08-04-2010, 07:31 PM
mudd746's Avatar
Car: 89 IROC Convertible
Engine: 305HO
Re: mounting detachable face in remote location?
Iv done it before in a monte carlo. any deck that was put it got stolen so i mounted the unit in the trunk and the face was flushed in the sun visor worked out great
Old 09-17-2010, 01:34 PM
gh86's Avatar
Car: '89 IROC-Z
Engine: 5.0 TPI
Axle/Gears: Stock 3.08
I have just been working on installing an after-market head unit in my 86 and I ran into a similar problem. The only thing that gets in the way is two vent ducts that feed the small vents that exit beside the front seats. My solution was to remove these ducts and leave the vents in place for aesthetic purposes, you loose two vents but you gain a stereo and retain CD and radio capability. The ducts are just fixed to the side and are quite easy to remove with a flat head screwdriver, the vents are held on by 2 10mm nuts. this frees up enough room for a standard head unit.
Old 09-17-2010, 02:33 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Axle/Gears: Stock / 4:11 Moser 9"
what kind of wire/connectors do you need to do this and where can you purchase them? i assume you need some kind of ribbon wire like in computers?
Old 09-17-2010, 06:12 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
cat5 or similar is usually pretty good for something like this, just make sure you can solder the connections (unless you feel like buying and identical model radio to grab parts from
Old 09-21-2010, 09:22 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
That sure sounds like a lot of work. Why not go with a ready made stealth system. They are very popular among classic and hotrod owners.
http://www.vintagevibes.net/Stereos/secretaudio.htm
Frozer!!!
01-19-2024 04:55 PM
ktthecarguy
07-05-2020 11:46 AM
Scamo-2.8
05-20-2016 07:01 PM
3rdgenparts
Exterior Parts for Sale
08-08-2015 11:48 AM
Quick Reply: mounting detachable face in remote location?
