Steering wheel radio controls 1988 GTA
Car: 1988 Pontiac Gta
My buttons on the steering wheel quit working. The ETR radio in showing LOC. I understand you cannot unlock the radio unless the Mute botton works on the steering wheel. Can you help me get started looking for the cause. Thanks Bob
Car: Restored 88 GTA
Engine: 5.0
Axle/Gears: Posi
Re: Steering wheel radio controls 1988 GTA
With the control pad pulled from the steering wheel but still plugged in with the ignition on, you should have 12 volts dc on the yellow wire, 12 volts dc on the grey wire (Lights on) 4.7 volts dc on the orange wire that will fluctuate when any key is pushed. The springs in the turn signal switch are part of the circuits. They do overheat and tend to get weak and fail. If you have all the voltages except the yellow (12 Volts) you can run a jumper from the fuse panel to the control pad to unlock your radio.
Please post your findings here.
89 GTA 355 (12-05-2023)
Attached is a diagram of the steering wheel controls.
I cannot get any power at yellow or grey wire. any thing else I can do.?
Thanks Bob
Thanks Bob
Engine: 5.0
Axle/Gears: Posi
You can jumper the yellow wire with 12 volts and jumper the black (Ground) to ground to see if you have 4.7 volts on the orange wire on the back side of the control pad. If you do have the 4.7 volts now, you should be able to unlock the radio since the orange wire is data sent across the led transmitters and recievers. If that works, that is good but you are still going to have to pull the steering wheel to find out what is wrong with the turn signal switch.
Thanks, I got the radio to work using your method, now I need to get the lock off of the steering wheel so I can inspect the turn signal switch. I'll probly make a tool to compress the spring so I can get the snap ring off. What might a look for as a problem I can fix or well I just need to get a new turn signal switch?
Engine: 5.0
Axle/Gears: Posi
Car: 1989 GTA
Hi,
This is my first post on 3rd gen,only joined a week ago - hope I'm doing the right thing with replies and postings.
Does anyone have a circuit diagram for the steering wheel audio control unit for a 3rd gen GTA Trans Am?
Mine is'nt working 100%, backlighting OK, but no controls are working. I've checked the voltages on the orange wire,should be 4.7V fluctuating when key pressed -but is only 0.7V and fluctuating around 1.4 to 1.6V as a key is pressed. Info from earlier in this post.
I can see that there are possibly 2 voltage regulators on the PCB - I'm wondering if one is a 5V that feeds the infra red LED driver has failed and is what is giving me problems.
Any help is much appreciated.
Regards,
Ken
Regards,
Ken
Engine: 5.0
Axle/Gears: Posi
Hi,
Regards,
Ken
Regards,
Ken
The yellow wire powers the control pad. More than likely the springs in the turn signal switch have failed meaning they shrank due to heat as they are a part of the circuit. You can try an alternate source for the yellow wire on the back of the pad from your cigarette lighter to see if the pad is functioning and to unlock your radio. I have been working on this type of system since 2008. Trust me, I know this system.
Engine: 5.0
Axle/Gears: Posi
Nice to have you on board! Use the diagram at the top of the page marked "Tom1" What you are lacking is a reading of 12 vdc on the yellow wire on the back of the steering wheel control pad (Plugged in and Ign on)
If you find you cannot get the radio unlocked, meaning no fluctuation on the orange wire reading, you may have a faulty control pad or the orange wire is not connected from the bottom of the steering column to the radio. I have several good pads if you need one.
Car: 1989 GTA
Thankyou for the diagram. Looking at it, I'd say that the fluctuating 1.5V that I see on the orange terminal on the Data Line of the pad would be about right.
The radio is working fine with the controls on the radio itself.
Your suggestion about checking the circuit downstream between the column and the radio sounds a good move. Thanks!
I'll know where to reach you should the pad look like it is faulty for sourcing another.
Thanks again!
Thanks again!
Engine: 5.0
Axle/Gears: Posi
Thanks again!
Thanks again!
Car: 1989 GTA
There is 12V on the yellow wire at the pad's PCB. The grey has 0.25V with the headlights off, and 0.86V with the headlights on. The pad backlighting works fine with the headlights on. These voltages along with the pad illminating sure looks like the pad is getting the right voltage - so this weekend I'll take a look at the radio end of the column.
Many thanks.
Many thanks.
Engine: 5.0
Axle/Gears: Posi
The problem resides in your control pad. If you have 12 volts there, the voltage on the orange wire would be 4.7 volts. Taking the pad apart carefully, look for corrosion as shown in this pic. If you have to clean it and it still does not work, you need a replacement pad.
Car: 1989 GTA
Hi - thanks for the picture of the problem areas - I'll take a look and resolder if necessary - guess that the joints could go dry after 25 years!
Anyone know where to find the connecting end down at the radio for the steering wheel controls? So a connector like the one in the radio for that smaller connector for the steering wheel controls.
I got a aftermarket stereo with the SWI-JACK making the steering wheel controls work and would like a proper connector to plug into the factory plug.
Car: 88 GTA Notchback
Axle/Gears: don't know
http://www.ebay.com/itm/Pontiac-OEM-STOCK-Radio-WIRE-HARNESS-PLUG-1982-UP-/380349142770?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3AFirebird&hash=item588e9356f2&vxp=mtr
Engine: 5.0
Axle/Gears: Posi
The cost to ship you a connector would be $46.00
Heres the shortcut; Take the CDM module off of the top/back of the radio. You will see the grey connector with a white and a black wire in it. Sometimes there is a brown one which you can ignor. The white connects to your orange wire in the car. The black connects to the black/blue wire in your car.
Hello,
I am reading your posts, and hope you have the answers to my problem? It sounds like you know this system very well. I have a 1988 GTA, with steering wheel radio controls. I bought this car, with this problem, the steering wheel controls did not and still don't work. " Only" the mute button. ( to unlock the stereo, "LOC" mode) Now this isn`t working either? My stereo is inoperable!! in LOC mode. Also, my door chime is dinging constantly, when key is out of ignition, doors closed, and engine off? I have to disconnect the battery to make it stop? The stereo itself worked beautiful when I bought the car ( But door chime still was a problem) until I put a new battery in the car over the winter. Now the door chime is constant, (unless car is running with key in ignition, then its off) but, stereo is in LOC mode, and won`t disengage, when I push "mute" on steering wheel now? Any help would be greatly appreciated? Someone told me it is a faulty turn signal switch and cancel cam? I can`t find one anywhere!!!! for an 88 GTA, if its even the problem? Thanks.
The radio control pad hooks into a yellow disk behind the steering wheel that rides on these "fingers" that stick out of the cancel cam. When I bought my car all the fingers were broken off. The ONLY way to buy a replacement is to get a used one. Look for someone parting a car, and put a post in the Parts Wanted section. I cannot help you with the door chime issue becaue mine has never worked (and I perfectly happy with that).
Engine: 5.0
Axle/Gears: Posi
You could have a problem with the key on switch in the steering column or a door switch. Follow the attached diagrams so troubleshoot your chime and controls problems.
Trying to get my radio unlocked/working. I see RED88GTA's image in #23, but my radio has two white wires on pins 6 and 7 and a brown wire on pin 3. Appreciate any help/suggestions.
EDIT: It appears my radio has 7 pins and RED88GTA's has 5. ugh...did I get wrong radio? If so, is there any way to make this radio work for me?
Engine: 5.0
Axle/Gears: Posi
If you have the black connector on the left, it is the wrong radio. The top of the radio will look like the one on the right. I do still have 3 of the GTA radio left, some with new cassette decks. LMK.
Car: 1988 Pontiac GTA
Engine: 5.7 l98
Axle/Gears: BW 9bolt with torsen carrier
Any more info on how to restretch springs to extend the (fingers). Thanks
Engine: 5.0
Axle/Gears: Posi
You will have to remove the T/S from the car, cut the p.c board off of the switch, re-stretch the springs and glue the board back in place.
1 Post
Car: Firebird
Engine: 3.1
Transmission: 700r4 /borg warner t5
hi
i have bought that kind of radio for my 1990 firebird 3.1 with the airbag steering wheel .is it possible to get it out of the loc mode? because i have no mute butten
can anyone help ?
can anyone help ?
Car: 1989 GTA
Hi red88tagta,
Since we corresponded a few years ago, I've purchased a Service Manual and in the past weeks have realised that my GTA does not have the original radio/cassette unit (the UT4) that it should have - no wonder the steering wheel controls don't work. It is a DelcoLoc II (CD player) - from some other GM car from around 1992.
Anyway - I'd like to put back a UT4 as part of my restoration. You mentioned in this post that you had some of these units - do you still have any available?
Many thanks - 89GTAOz.
Engine: 5.7
Is there anyway some one could post a picture of the pigtail that plugs into the wires from the radio controls at the bottom of the column? Thanks for any help!
Tim88GTA (11-11-2019)
Engine: 5.7
Car: 1989 GTA
Hi Tim88GTA,
Sorry for the delay in replying. Are you wanting a picture of the connector that contains the steering wheel control signal input to the radio?
There are 3 connectors, 2 for the speakers, power, antenna up/down etc and a third just for the steering wheel control signal.
Regards, Ken.
Regards, Ken.
Engine: 5.7
I figured out what plug went to the radio control wiring at the bottom of the turn signal cam switch harness and i found the same colored wires where the radio goes. Someone cut all the factory radio plugs before I got the car. The plug pictured above is the one that hooks to the radio control wiring at the back of the radio correct? I'm just trying to make my steering wheel controls work for an aftermarket head unit.
Thanks for your time and help with this.
Car: 1989 GTA
That plug is the one.
The orange wire is the signal input from the steering wheel control - it connects to the first wire (orange) of the connector I sent you a photo of.
Good luck with your aftermarket head unit - you are probably using one of the conversion units (PAC SWI adapters)?
Ken.
Ken.
Tim88GTA (11-20-2019)
Engine: 5.7
Yeah I guess the converter is my only option. Are the 2 wires in the plug the only ones that come to the radio from the steering wheel controls?
#42
I was very fortunate to have just found this NOS radio for my 88 GTA from a guy with a 15,000 sq ft warehouse full of factory new or refurbished old gm radios.
#44
Engine: 5.7 l98
Need a little help on this old post. Put a new horn pad on and steering column. I have power to the gray with headlights on but no power to the yellow my radio isn't currently hooked up would it need to be to have power to the yellow?
backtothe80s
09-05-2015 12:39 AM
