Best 12in subs for around $200?
I need 2 12in subs for a Q-logic custom fit camaro box for an 89 Camaro so the box volume is .85cu/ft per sub. They will be run by an Earthquake Thrust 500 amp putting out around 560W RMS bridged. They will be mainly used for rock and alternative. The shop owner recomended JL W6's, are ther any other options?
I don't understand why people keep recomending w6's when there will only be 2 in use. 2 w6's will yield either 6 ohms, 1.5 ohms, or 24 ohms. I don't know of too many amps that will give you the best performance out of any of those loads.
As for the question, any of the following would be a good consideration...
- IDQ 12
- Kicker C12 or Solo 12, however the solos are no the fastest responding subs, their better for loud bass, not tight accurate bass (i.e. more suited to bass heavy music than rock or jazz type music)
- Eclipse 8812
I've heard good about the Infinities and Pioneers as well, but can't say as I've had much experiance with either.
Just about any good name sub is going to perform well in that enclosure size. Just be careful of what load you present to the amp and you should be fine
L8rs
GndPrx
http://www.caraudioresources.net
- IDQ 12
- Eclipse 8812
L8rs
GndPrx
i like rockford subs i have 2 12's and a precision power pc 275 running 300 watts ot 4 ohm mono im hitting a 136.4 and trust me its eough to make your hair move
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I used to run 2 10W6s. Bridged, they were running at 1.5 ohms off my Alpine V12 amp and it never had a problem with the load. Used to hammer like mad, but i switched to 1 10" to save space and weight. My friend runs 2 15w6s off a Phoenix Gold amp and it'll rattle your brains out. If your amp can handle a 1.5 ohm bridged load, go for it.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
[This message has been edited by Justins86bird (edited October 09, 2000).]
-Justin-
12W6s will cost more then $200 each. Last time i checked, they were like $275, but that was in town here.
-Justin-
-Justin-
Will an Earthquake Thrust 500 amp be able to handle a 2ohm bridged load? It only lists bridged at 560WRMSx1 @4ohm. It will run 275WRMSx2 @2ohm. What do you think it will push the subs at in 2ohm bridged? I plan on putting a big fan on it and it is out in the open. These are actually tested parameters at 12.5Volts from the birth certificate in the box. What class amp is this, A, B, AB, C, D?????
My local guy wants $199 for the 12W6's. They are dual voive coil right? So can I just use one 6ohm voice coil on each sub and wire them in parallel? That would be (1/6omh)+(1/6ohm)=(1/(2/6))ohm and that would give 3ohm total impeadance and would that result in more power than a standard 4ohm load, and would that setup not heat the amp up as much??? If I got something wrong let me know, specifically if you can use only one of the voice coils on each sub???????
try these:
audiobahn
12"" Ultra Excursion Sub 180oz mag
Model: AW1205
$205.00
12 In. Ultra Excursion Subwoofer, Massive 180 oz. Double Stacked Strontium Magnets, Power Handling: 1000 watts R.M.S. , Frequency Response: 23Hz - 700Hz, Efficiency: 92.9 dB , Bolt-Tight Motor Structure , Chrome Plated, Cast Aluminum Basket , Machined Chrome Back Plate, Extended & Vented Pole Piece, PHAT 2 In. Foam Surround, Laminated Glass Fiber Composite/Pulp Cone, Nickel Plated Lug-Lock Terminals, 3 In. 4-Layer ASV Voice Coil, Dual 2 Ohm , 1 Ohm or 4 Ohm Operation , Heavy Duty Wooden Gift Case
84 z28 build up-
things got:
383 balanced and blue printed short block, 11 to 1 compression pistons, gear drive
,525 total lift cam, hooker comp headers ( jet hot coated), all paint needed to show, new fenders, 4 3/4 cowl induction hood, new nose, new rear bumper, 3.73 rearend (stock)
things getting soon:
preditor carb, victor jr. intake (jet hot coated), blower style air cleaner
this winter:
afr heads or vortech heads
audiobahn
Model: AW1205
$205.00
84 z28 build up-
things got:
this winter:
-Justin-
I'd say go with the kicker C12's.I've had mine since 95 running off of a punch 200 since 96.To this day they will still nock your hat off.
[This message has been edited by Kevin S (edited October 09, 2000).]
Originally posted by evilho7810:
Kicker Solobaric subs.
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
199 for a w6 aint bad,.. yeah your 3 ohm theory should work.. im qassuming its a 4 channel amp by those stats?
[Sold] Flowmaster exhaust system
Night rider327
10-09-2015 09:25 AM
TMZIrocZ350
10-07-2015 12:09 PM
