Will this be ok for me?
Old Nov 24, 2000 | 09:27 PM
Sweet_85_Bird's Avatar
I like a little bass,just enough to feel it,and was wonderin would this do it.
Im going to have a 12" sub in a sealed box down in the well firing up at the glass w/a 200w amp pushing it.Would this be ok for my needs?
Old Nov 24, 2000 | 11:06 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
If you're just looking to fill out the bottom end, a single 12" will be more than enough. Even a single 10" system can be loud enough to make your insides vibrate if you have enough power.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Nov 25, 2000 | 12:14 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I have a single JL 10W6 getting 300 watts RMS and i can feel it.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
Old Nov 25, 2000 | 02:37 AM
daniel dekay's Avatar
my friend has a single JL in his Volvo s40, its all the way in the trunk and i can feel it just fine. so i only would assume the camaro would make it slam a little harder cuz of the natural bandpass on the rear lift gate.
daniel
Old Nov 25, 2000 | 03:52 AM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
I did that with two 6x9s before I got an amp!! I mounted them in the well cover,good acoustics. I think three 10"s 600 watts is good
Old Nov 25, 2000 | 10:33 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
1 12"? THat's what I have, and it's more than I need! It gets really loud (I estimate 135 db)
But, it is a Solobaric L7 (The square one) and I have about 750 watts to it.
But seriously, a basic 12" with a couple hundred clean watts to it should be just fine to liven up the bottom end a little.
I did a 91 RS a while back with 1 Kicker Comp 12", and a couple hundred watts from a Clarion amp, and it was pretty sweet. I say go for it!
Working on:
'84 Z28 LG4 305
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is in shop!
Awaiting results from all 8 ASE tests.
Starting to look like the Kicker poster child!
Old Nov 25, 2000 | 11:18 PM
Topgun's Avatar
I myself have a single 10" Sub in a sealed box and 150 Watts rms being pumped into it. And man, i can't imagain the bass. My radar dector on the windsheild bounces with th bass. It is amazing, especilly for a single 10"! (Firing up at the glass)
EMAIL: CTopgun5@aol.com
_______
84' Z28
New 350 Ci 4 Bolt Main with all L69/HO Parts
4 BBl Carb
180º Thermostat
K&N High Flow Filter
700R4 Trans
15X7 Standard Z28 Wheels, With 215/65R15 BF Goodrich Comp T/A HR4 Tires
Charcol in Color
no T-tops, but wish
New Head unit, JVC KD-SX750
New Kenwood 3-Way 6X9's KFC-6906S
New Pioneer Sub TS-W253C
New Jensen 4-Channel Amp XA-4150
As FiremanZ28 says "Friends don't let Friends Drive Mustangs"
Pic of my Z28, thanks to ZZ4 and his web page: Http://www.geocities.com/ukzz4iroc/z28camaro.jpg
[This message has been edited by Topgun (edited November 25, 2000).]
