Wiring in amp to factory radio
1 Post
Car: 89 GTA, 84 T/A
Engine: L98 stock, Carbed 350
I want to add and amp and new speakers, but would like to use a line converter to keep my factory radio. Can someone confirm that I have this wired correctly.
I want to make sure that the remote wire is correct, also is it alright to use the factory wiring to run the new speakers?
Re: Wiring in amp to factory radio
Looks good. Just one thing. If sound quality is high on your priority list, then using a high level to low level converter is not a good solution. It introduces an entire stage of distortion. Kind of like making a photocopy of a photocopy. If I were to do this, I would get a Bose factory head unit and use the speaker outputs directly into the amp. The Bose output is a low level input already (preamp level).
1 Post
Car: 89 GTA, 84 T/A
I have never seen one of the Bose units, and it would probably cost more than I want to spend. Do the later Monsoon units operate the same, or is there a way to bypass the amp in a regular factory radio, and get the necessary pre amp signal that way?
