Recommended way to incorporate a subwoofer?
I have a Delco-Bose head unit using the front speaker outputs to a Rockford Fosgate Punch 150 driving two pairs in parallel of Polk 4-ohm speakers (6.5" separates up front, 4x6 2-way plates in back). The system sounds great but I would like to add some more bass to help relieve the low frequency stuff and hopefully get more overall clean sound out of the system.
I have a Bazooka dual 4-ohm coil 10" passive tube. I hooked it up 4-ohm single coil bridged across the setup and it sounds ok but muddy. Much cleaner without it.
I have another Punch 75 amp I could bring into the picture and perhaps use the rear channel outputs from the head unit, or just split the current audio signal.
Recommendations? Ideas? Active crossover?
Transmission: Pro-built 700R4
Re: Recommended way to incorporate a subwoofer?
Are you insisting on keeping the stock head unit?
Car: 89 Firebird
Engine: 355 TBI
I ran a Rockville 10inch speaker/amp combo in one in my truck recently and love it! Very easy to hookup $139 Amazon
That is unless you're already running a capacitor in line to the 4x6s. If not a 250uf cap on each side of the positive wire going to the 4x6s would cut 160hz by -6dB and would let you get the most out of the 6.5" up front (able to increase the bass frequency adjustment). They're $7 plus shipping.
https://www.parts-express.com/250uf-...citor--027-370
You shouldn't have a problem running another amp off the rear output giving you a front fade to the 6.5s and 4x6 and rear fade to the sub. It's not recommended to only run one coil of a dual coil sub. You really need to run a low pass filter so the sub won't play higher frequencies. Harrison Labs make some inline RCA filters. I've never used them but know a couple people that have and they seem to work fairly well, but tend roll off a little higher than the advertised frequency. I'd think you would need a one of their 100hz filters for around a true 150hz roll off. They're $26 at PE. Should be around $40 for both the caps and the crossover shipped and should make a big difference.
https://www.parts-express.com/harris...s-rca--266-254
Now; It's common knowledge that on a factory BOSE system the sound for any speaker is determined by the AMP driving it. I was rebuilding some BOSE Amps last week and had a BOSE system set-up for testing purposes. I used the same Delco radio as your head unit,.... Camaro/Vett BOSE cassette. It's only got FADE control and - as you describe - the head unit doesn't entirely "kill" the sound from the front or back when fully adjusted one way or the other. ( that's normal with BOSE ).
There is a (normal) tremendous amount of difference in sound from LEFT to RIGHT. But I wanted to know if the front and rear output the same sound or not,...... so I placed the exact same type of speaker on the RIGHT Front and RIGHT Rear plugs and used exactly the same type of AMP to power each speaker. ( 4" full range Speakers each with it's own 100watt GM BOSE AMP. ) When comparing the sound there wasn't much of a difference but I DID notice a difference. I had to listen for a second - but after switching from front to back....... The "highs" such as - cymbals - were more pronounced on the FRONT channel.
Before diving in and re-configuring things in a big way,...... try just taking the signal from the rear channels first and see what you think.
Looking at ways to connect up a sub with the cabin speakers so that the sound is proper and not muddy.
Right now I have a Punch 150 connected to a Delco-Bose. Sound is clean but can get muddy at higher levels. The 150 will routinely blow 20A fuses so I know it's getting good power.
It's running a front set and a rear set, all in parallel (2 ohms). When I bridge the sub across it, it's too much load plus the sub has no crossover.
From what I see, I think an electronic crossover is needed. I will also throw my Punch 75 in as well and likely use that to drive the sub. Or maybe I can just ditch the rear speakers. They are Polks.
The fronts are 6.5" 2-way separates with a passive crossover. I got the 6.5's into the doors and sound prepped them. They make nice bass but for the sound levels I want, I need to free them up from the lowest frequencies and let the sub handle it.
I'm really sniffing around these:
https://www.crutchfield.com/p_1616XS....html?tp=61661
or
https://www.crutchfield.com/p_1612XS...2XS-Black.html
or
I'd suggest SOME sort of signal processor. I'm running the Clarion EQ746. ...I've used it with two different radios...a Delco BOSE and an aftermarket pioneer. With the EQ it made a phenomenal difference in clarity and sound quality.
Good deal, that 2XS is a nice super clean piece of equipment and will complement those old school punch amps well. I'm sure you'll be very pleased with the results.
Pretty sure the stock TPI alternator is 105amps so you should be fine. Might want to check out this link for info on what gauge wire and fuses you'll need to use.
http://www.bcae1.com/wire.htm
You might not have to do a big four upgrade, but if your lights do dim at volume, that usually takes care of that. You would need at least a 4 gauge positive wire running from the alternator to battery, 2 gauge ground strap from the alternator to frame, 2 gauge ground from the battery to the frame, and at least a 4 gauge from battery to body.
By the way, that punch 150 puts out about 180-170watts per channel into 2ohms at 1%THD at 13.5V and probably around 200 per at 14.4V
https://www.amp-performance.de/683-R...Punch-150.html
I'd suspect the Punch 75 would make close to if not more than 400watts bridged into 2ohms - assuming it doesn't overheat and pop fuses (it should be OK though)
I threw one of these in the trunk. liked it because it's small, low profile, and can be easily hidden. has a built in amp. it's 150w. and i didnt have to change the stock alternator to power it. did change the head unit to a modern day one. granted, you're not going to get as much bass as dedicated 12" subwoofer(s) and amp, but it's pretty good for it's size.
https://www.bestbuy.com/site/kicker-...?skuId=3526208
Car: camaro84.87iroc,91vert
Engine: Lt1, 383tpi,350tbi
Transmission: t56,T5,T5
Axle/Gears: 4thgenunknown,373,323?
That is a great set of amps you’re using
hanks for all the help. I finished the install today. Wow it really cranks. Van Halen sounds best, I wonder why? ;-)
The Punch 75 is driving the passive 10" Bazooka sub (dual 4-ohm voice coil paralleled for 2 ohms load) bridged mono to the amp off the low pass output (33Hz to 90HZ) of the 2XS. The Punch 150 is driving front separates in parallel with the rears for a 2 ohm 2 channel load off the high pass (90hz and above).
All fed from an era Delco-Bose head unit with an added bluetooth aux input
They are some old amps but they still put it out. I'll touch them up later and finish tucking the wires in.
Got it all dialed in. Needed to lower the crossover to 70hz from 90hz. The cabin speakers- front 6-1/2" Polk separates (in door and dash) and rear 5x7 get everything above 70hz. The sub gets everything between 70 and 30. Man this thing goes loud and sounds great for all kinds of music. All I adjust is the bass slider on the old Delco-Bose head unit. It goes from about the middle (heavy bass tracks) to max (Van Halen, 80's pop, etc). Amps just get warm, that's it.
Thanks John. Head unit works flawlessly!
Can you keep an eye out for a Delco-Bose badge for the front of the head unit? If you recall, the previous owner of mine had some strange and pretty extensive rubbing wear on it. I'd love to show it off again. Thanks again, great work on the HU!
I have - and will continue - to keep an eye out for good emblems. All I can see to find are the damn speaker emblems; I KNOW that someone was selling the radio emblems in the past, but just can't seem to find any now ! You can still find complete NOS face-plates for about $70 - but I can't find that damn radio emblem itself anywhere and it's drivin' me
