Post Your Carb'd Motor Pics
#1102
Car: 1984 Firebird
Engine: 388 CI, Lunati Cam, Ported Heads
Transmission: 700r4 Pro-Built
Axle/Gears: 3.23 10 Bolt with mini spool
#1103
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
Re: Post Your Carb'd Motor Pics
Here's a picture of a 355 I built back in 1999. 12:1 compression ratio, TRW forged dome pistons, Chevy pink rods, ARP bolts, ported 2.02/1.60 Bowtie heads milled to 62cc, solid roller cam, Team G intake, Cloyes double roller timing chain. Ran 11.10's - 11.00's at 119 mph. 1.54 60' times. Later slapped a set of Dart builders heads on there and Improved to 10.8's.
I'll have to get my 305 pics up
#1105
1 Post
Car: 87 Trans Am
Engine: 355 Carb. Nitrous 100 shot
Transmission: TCI Performance Trans. 350 Turbo
Axle/Gears: Borg & Warner 9 bolt 3.70 gears
Here's mine. though this year I will be adding Twin Turbos.
#1107
and this gentlemen is how not to do a carbed engine/carb swap
no i didnt do that po did it they removed the l98 and swaped in that engine
to remove the ecm wiring they took bolt cutters and just cut the harness leaving it under the hood
this is what it looked like one day after i got her home
after about a week i said fug it and put the tpi back on it and put twin turbos on it
#1109
Car: 84 Camaro Z28
Engine: 350ci sbc
Transmission: th350 reverse manual valve body
Axle/Gears: 10 bolt 4.11 gears
#1110
Car: 84 firebird
Engine: 355
Transmission: 700r4 stage 2 shift kit 2500 stall
Axle/Gears: 3.42 posi
Here is my work in progress
#1111
Car: 1992 camaro rs
Engine: 92 350ci carbed
Transmission: 700r
Axle/Gears: Stock 10 bolt 2:73 gears 😭
How in the world do I post pics on here?
#1113
Car: 1984 Camaro Berlinetta
Engine: 5.0 305
complete engine rebuild, working on the paint right now, all Edelbrock performer series
#1114
Car: 84 firebird
Engine: 355
#1115
Car: 1992 camaro rs
Transmission: 700r
#1116
Car: 84 firebird
Engine: 355
ohh ok lol i had a set of headers i ended up using muffler cement on because no matter what set of gasket i had they would leak was wondering if you had the same problem haha
#1119
Car: '83 Z28
looks better than it did a couple years ago. still gotta couple things to take care of.
#1123
Yah, I'm putting them on next weekend, 355's, flat tops, comp268h, 1.5 comp roller rockers, performer rpm, 1" spacer, and 750dp.
Should work good....I hear some pretty amazing things about them and they look like art lol.
#1124
#1125
Car: 72 nova/ 90 camaro rs,04 suburban
Engine: blown 327/ 355/306/355/5.3
Transmission: muncie 4 speed/T5/powerglide,4l80e
Axle/Gears: 342/411/456/ moser axles
mine is a 355 full roller engine, eagle crank, eagle I beam rods, lunati 11-1 pistons 030. 010 4 bolt block, sportsman 2 heads, manley valves 202/160, comp solid roller cam, comp roller lifters,Comp roller rockers 1.52, manley push rods, comp true double roller chain, comp matching springs, retainers, 10deg valve locks, holley strip dominator intake, Holley vaccum secondary carb, all msd electronics T5 trans, I still need to go through and remove all extra wires not needed!
#1128
1 Post
Car: 1986 Chevrolet Camaro
Engine: 355 chevy
Transmission: t-5
Axle/Gears: 3.73 disc brakes
not perfect still need new spark plug wires and electric fan wires have been cleaned up. world product sportsman II heads, hooker headers, thumpr cam (279/297 lift not sure have 1.6 rollers) edel carb and intake
#1130
Here is my son's in his 1986 Z-28. It's a 355 with TRW Forged Flat Tops, polished GM pink rods, GM 492 heads w dual springs, guide plates and screw in studs, Comp 292 cam - degreed in, Cloyes Double roller timing set, 1.5 Roller Rockers, Wieand Single plane manifold and a 770 Holley Street Avenger on it. All Balanced and Blueprinted. Its his toy that we built together. Fast as all get outs and backed by a Tremec TKO600RR going to a 3:23 posi. Shifts at 7000. Haven't got it to the track yet but we suspect 11's the way it runs.
#1131
Car: 83 Camaro Z28 (CFI)
Engine: 305 V8 (CFI)
Here me 84 i just bought 3 weeks ago :
http://imgur.com/a/SRQyL
Engine specs:
SBChev 400 HP - block # 3951511 - 1970-73
.40 flat tops / roller rockers / edelbrock performer rpm heads / comp cams thumper cam / eldebrock performer rpm high rise intake / Holly 600 carb #80457-7 .
Ignition:
Mallory coil # 29440 / msd street fighter cdi multispark ignition # 5520 / Msd distributor #8361
I still have a crap load of work to do on 'er, have already soaked an addition G into fixing the PO's goober screw ups, still need to put in another G to get everything right
* Can anyone identify those valve covers ? I can not find anything about whom the manufacturer may have been.
Engine specs:
Ignition:
#1132
Car: 92 Camaro RS
Engine: Carbureted 396ci smallblock
Transmission: 700R4 with shift kit
Axle/Gears: 8 inch, auburn posi unit 373 gear
Who makes your strut tower bar?
#1134
Car: 92 Camaro RS
Engine: 350 ci Carb
Transmission: 5speed
the holley in this pic is junk. waiting for a new carb.
but, it's a 350 L Code crate engine. ported and polished heads. mid length headers. .468 lift cam. edelbrock torker2 manifold. 1" carb spacer. running AC Delco plugs with 8MM wires. Lightweight flywheel.
Mated to a T-5 manual trans
**this was also before i had a chance to clean up the new wiring and do some more cleaning and make it look pretty. this is right after i test fired the engine and broke in the cam.
#1135
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
That isn't a Torker II intake in your picture (which I would consider a good thing, by the way...).
#1140
Engine: LS1/LQ4
Sorry for the confusion.
(Still don't like the Torker intakes...)
#1143
Car: 1991 Camaro Z28
Engine: 350ci TPI
Transmission: built 700r4
Axle/Gears: 4th gen rear end
This is my set up that im currently building on my tpi to carb swap, it was a tpi 350 but ditched out the tpi and adding the intake airgap rpm with a 750 db holley with a 288 comp cam and ina month ill be ordering a set of profiler 195cc heads , i will post more pics once i have everything bolted up
#1146
Car: 1983 Chevrolet Camaro Z/28
Engine: 383 Stroker
Axle/Gears: Posi/3.73
Nothing special but it's my daily driver for now.
Also, it no longer has that triangle of death on it. :P
#1149
Engine: 383 Stroker
#1150
Car: 1988 Trans Am GTA
Transmission: TH-7004R
real engines are DIRTY and have hoses running EVERYWHERE!!!!!!!!!
