carb spitting gas and boggin out when give gas
Car: 1987 camaro lt
Transmission: stock
Axle/Gears: stock
hey everybody got a question first off just got an 87 lt camaro 305 with roch. carb had carb rebuilt and got car running but its spitting gas out the carb(too rich?)and boggs out when i give it gas. im thinking its the eletric choke but i dont know. really could use some advice thanks everyone
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: carb spitting gas and boggin out when give gas
the timing may be too retarded.
Car: 1983 z28 and 3000gt twin turbo
Engine: 305 v8
Transmission: auto with b&m shifter
Axle/Gears: i dont know. they're stock
is it flooding? mine did that when it was flooding, my choke was/is bad. do you know where your choke is? check and see if its getting stuck on like mine was, its on the left side if your looking at the front of the vehicle.
Car: 1987 camaro lt
Transmission: stock
Axle/Gears: stock
hey its not flooding but when messing with it yesterday noticed the choke wasnt opening up. does anyone know where to get an eletric choke for a roch carb? looked at auto parts stores here and cant find one. but even when i held the choke open it was still running ruff. any ideas?thanks.
Engine: 305 v8
I just pulled mine off an old rochester that someone gave me, he used to work on carbs. I would just go around town and ask a few shops
Car: 1987 camaro lt
Transmission: stock
Axle/Gears: stock
ok so got the choke working. and carb was just rebuilt by a carb shop here.runs now but no power when hit gas. tired adjusting the carb didnt seem to help
Engine: 305 v8
hmm...sounds really close tot he problem im having, i'm still trying to figure it out too. do you know if your secondaries are opening?
Car: 1987 camaro lt
Transmission: stock
Axle/Gears: stock
the secondarys are opening but its spitting gas out the top and boggs when giving it gas
Engine: 305 v8
Car: 1987 camaro lt
Transmission: stock
Axle/Gears: stock
i dont think its the timing cause when its just sitting it runs fine till you give it gas but ill check the timing tomorrow just incase
Car: 1987 camaro
Engine: 383 AFR heads
Axle/Gears: Ford 9" 3.70:1
Where is is spitting gas from? If it boggs when you are sitting in your driveway (no load) you probably have a timing issue. I had a similar issue. It could also be that the tension in the spring that holds the secondaries closed is to light. Try holding the secondaries closed and throttling it and see if that fixes your problem. There are two squirters, one in each primary hole, that squirts gas into the bore when you give it gas. Is it maybe one of these splashing against the bore that you call spiting?
Car: 84 Z28 / 99 S-10 ZR2 4X4
Engine: STOCK CARB'D 305 WITH 350 HEADS
Axle/Gears: STOCK
i got the same problem but it seems it only does that if i dont let it warm up first..
Car: 1987 camaro lt
Transmission: stock
Axle/Gears: stock
red but going to be nice cherry red by next year hopefully
Car: 1987 camaro lt
Transmission: stock
Axle/Gears: stock
ok its vspitting up throught the main ports,and not just alittle splash. and if its timing how do i correct the prob?
anybody live on long island and want to help me get this running....only car and need it running will make worth ur while $$
