Holley Fuel Pressure Regulator
Car: 91 R/S - IROC-Z SUSPENSION
Engine: 1970 350 LT1 BORED 30 OVER -355/
Transmission: 5 SPEED
Axle/Gears: 3.73 12 BOLT POSI
A friend of mine just replaced his fpr on his camaro 350 carbed engine,and he brought to my attention the diagram holley has for the install of the 12-803 . The regulator itself has 3 ports ,1 on each side going out clearly marked out ,and the bottom port is marked in,pretty simple we all know.But the instructions he showed for that particular regulator states that the bottom port is for the return line to the tank and the side ports are fuel in ,and fuel out. How many of you noticed this before? I have the same regulator and have mine plumbed with the bottom port as fuel going in ,and 1 side port to carb and the other side port as a return to the tank,I even checked the Holley site and the instructions say the same as the paper instructions. Did Holley change things up ? This is a first for me ,never noticed this before.
Car: 86 sport coupe
Engine: 355
Transmission: 5speed
Axle/Gears: 3.73 detroit locker
Re: Holley Fuel Pressure Regulator
I have mine fuel in bottom port. 1 side port to carb. Other side port plugged. those instructions are F'd up. I have a return on my pump.
I agree.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Sounds right if you were going to connect it as a bypass regulator.
Are you referring to the Holley instructions ? Using the bottom as a return and the 2 sides as fuel in and fuel out to carb?
Engine: 383 Carb
Transmission: 4L60
Yes, check the instructions: http://www.holley.com/data/Products/...199R7914-3.pdf
Page 3 has 3 figures. Figure 1 is for the deadhead regulators, the 12-803, 12-501, 12-804 and 12-500. Figures 2a and 2b are for the return regulator, 12-803BP. It's explained at the bottom of Page 2.
Engine: 383 Carb
Transmission: 4L60
The significant difference isn't the pressure, it's whether it's a bypass regulator or not. That's the "BP" suffix on the part number. If you have a "BP" regulator, you need to use Figure 2. If it's a non-"BP" regulator, you need to use Figure 1.
Thanks Apeiron, All this time I have been running standard regulator when I thought I was running the bypass style. I actually have the original box it came in and it was marked as a bypass reg ,and instead the 1 in the box was a standard reg,I never looked when I installed it. Thanks to my buddy and you I now realized it...It was like dead heading the pump,now I know why I killed 2 factory intank pumps a few yrs back...Glad I did not toast the holley it's amazing the car ran so dam good ...Thanks again..............
Engine: 383 Carb
Transmission: 4L60
How do you know it's a standard regulator?
The Holley pump has an internal bypass inside, so you can use it with a deadhead regulator. You'd find things would run a lot quieter and cooler with a return regulator, though.
The non by pass regulator would be considered stand regulator #12-803...Like you said the bp was the one I wanted. Just got back from the speed shop ,got the bp style.Even got it for free since I showed the box to them and they realized it was packaged wrong. That was over 3 years ago.
Car: 89 IROC Z28
Engine: 5.7 L Edelbrock perf /holley 3310
Axle/Gears: BW 9 BOLT 3:27
i have the red holley elec pump and i am using the 803bp regulator and the most pressure i can get is 4psi. is that because of the return line to the tank. maybe i don't need the return but i heard it cools the pump or something.
Engine: 383 Carb
Transmission: 4L60
You don't need a regulator with a red pump. It has a 7 PSI bypass spring in it, so the most pressure you'll ever have in the line at the pump exit is 7 PSI. With pressure drop in the line to the front, you'll have less at the engine.
Car: 89 IROC Z28
but i/m using the return line that goes to tank. should i remove the regulator and the return line and plug it at the tank
Engine: 383 Carb
Transmission: 4L60
You don't need a return line with a red pump either. Try pinching off the return line and see what happens to your pressure.
Car: 89 IROC Z28
o.k. it spiked to 6psi. instead of going to all the trouble of removing the regulator and nice alum return line could i just remove the spring from the regulator
Engine: 383 Carb
Transmission: 4L60
Up to 6? is this a new regulator or an old one?
If you removed the spring from the regulator you'd just be sending all your fuel back to the tank.
Car: 89 IROC Z28
it is only a couple months old, the red fuel pumps max pressure is 7 psi
9192camaro
16
02-03-2019 12:21 AM
1970, 305, 803, adjust, camaro, carburetor, fuel, holley, holly, pickup, pressure, regulator, regulator12803bp, regulators, settings
