tbi convert to carb
Car: 90 camaro rs ttops
Engine: 350 tbi
Axle/Gears: 323
tbi convert to carb
i have a tbi setup and i want to convert it to a carb setup. what all has to be done to make this happen. any suggestions
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: tbi convert to carb
well that depends... are you going with a 82-87 carb setup? or are you going with a non electronic aftermarket setup... your TBI is computer controlled, so if you are going to go with an aftermarket setup, then you will need to replace your distributor to a vacuum advance system... you will have to install a fuel pressure regulator in order for your TBI fuel pump to work with your carb setup, ... there are other things you will have to do as far as wiring goes... but probably something you should be able to do with a diagram...
Engine: 350 tbi
Axle/Gears: 323
im wanting to go with a high rise intake with a 4 bbl carb and considering a mallory fuel regulator and i want to get rid of all the computer wires but im not sure what problems that will make. i want the simplest convert because this is my daily driver and i dont have access to a garage to work little by little.
Engine: 5.1 4bbl
You will also need a Transmission Torque converter lock up, I believe it's computer controlled on your 'maro.... just be patient someone with better info will come along and point you in the right direction...
Engine: 350 tbi
Axle/Gears: 323
the trans wont be much of an issue i am putting a manual in soon.
Engine: 5.1 4bbl
https://www.thirdgen.org/forums/sear...archid=3255820
look through these posts and get acquainted with TGO
Engine: 5.1 4bbl
in the search box... just type in, with parenthesis
"tbi to carb"
"tbi to carb"
Car: 87 GTA
I just wanted to let you know that there are 2 tech documents on this topic under the technical doc section. Just click on the "Home" link at the top and look at the links to the left of the page. They are very informative and full of the info you need.
theshackle
03-05-2017 06:37 PM
350, 57, 700r4, 87, camaro, carb, carburator, carburetor, converfting, convert, converting, convertor, hooking, lock, tbi, transmission, work
