Duty Cycle set to 50% but...
Car: TA
Engine: 5.7 CCC
Transmission: Manual
Axle/Gears: 3.70
my car still has an exhaust smell to it (lean, I think). With dwell varying around 30 can a car still be running either lean or rich?
Thanks...
Thanks...
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Duty Cycle set to 50% but...
Yes, but it's unlikely.
The O2 only sees the left bank and a problem there could confuse it into richening the mixture but most issues will have the dwell pegged all the way.
One member here had a vacuum leak off of the manifold source that feeds the accessories that showed good, varying dwell but still caused an overly rich mixture. Try plugging that source and see if there's a change.
Chances are though that everything's normal and you're just smelling a bad cat or exhaust leak.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
I'm not sure lean exhaust smells (but I don't have much of a sniffer).
A weak O2 sensor can tell the computer it needs to give the engine more fuel when it doesn't need it. If you don't know how old your O2 sensor is, it would be worth the few $'s to go ahead and replace it now.
Are you running headers or the stock manifold? Also, what temp thermostat do you have? Running headers cools off the O2 sensor. Also, anything less than 190* stat can have the effect of the 02 sensor not reading right because it doesn't warm up enough. This is my problem.
Car: TA
Engine: 5.7 CCC
Axle/Gears: 3.70
I want to drag this out and give 3 guess as to my problem but i wont. I am currently running a roller 350 block w flat-top pistons and an l69 top end. my problem was to much timing. took it down from 8 to 5 and now she's running like a champ. Thank you everyone for your replys. Naf, thanks for all of your postings. you have helped me on numerous occasions, one way or another...
thanks again everyone
[Sold] Accel 30# injectors
hydrolic144
08-29-2015 04:14 PM
