hood clearance
Car: 1985 Pontiac Trans Am
Engine: 305 smallblock aftermarket cam
Transmission: Borg warner T-5
hood clearance
I have a 85 pontiac ta and i have the stock H.O intake and qjet on it and im wondering if i purchase a low profile intake with a edelbrock carb will it fit under the hood??? i have a stock vented hood
Re: hood clearance
What would you suggest?
1 Post
Car: 1982 SC/1984 Z28
Engine: 305 4BBL/305 4BBL H.O.
Transmission: 700R4/700R4
Axle/Gears: 4th Gen 3.23 Posi/3.73 10 Bolt
Re: hood clearance
The Quadrajet IMO is a Superior Carb. It flows more and is more gas efficient for example.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
The stock q-jet is the superior carb by far.
Go the the FAQ forum and look for a thread about the differences between 305's and performance upgrades. It details what constitutes an "upgrade" to a factory 305. The carb is the last thing on the list - for some reason, people seem to put it first on their lists.
Re: hood clearance
Ok. well the qjet on my car for example does not run the way it should. Maybe when they were new they ran good but after 25 yrs they dont apparently. lol Last night I ran a stock GMC sierra with a 5.3 in it and it beat me which should not have happened. The reason for that is because when the motor is up in the revs the carb cant keep up. So imo theyre junk atleast this one is anyways.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: hood clearance
The carb is capable of flowing air for as long as the engine underneath will keep sucking it in. The stock exhaust, cam and heads limit an L69, not the stock carb.
A Vortec 5300 makes about 285 HP and 325 ft-lbs or so in a truck that could weigh as little as around 3900 lbs. An L69 has 190 HP and 240 ft-lbs, and weighs about 3400 lbs. You've got 1/3 less HP, 1/4 less torque, but you only weigh 1/8 less. No surprise you'd lose.
Re: hood clearance
Here's the specs on my 305
416 heads
lunati barebones cam http://www.summitracing.com/parts/LUN-10001LK/
shorty headers with 2.5" exhaust
stock intake stock carb
flat top pistons forged
stock rotating assembly
416 heads
Engine: LS1/LQ4
What air cleaner are you using?
Why the 2.5" exhaust? It's a bit smallish, even for a 305.
Re: hood clearance
this is what she looks like
Re: hood clearance
This is my backup motor
Engine: LS1/LQ4
An HO carb shouldn't have flow capability issues. Some LG4 q-jets were flow limited, but not the L69's.
Like Aperion said, I wouldn't expect a cam'd/headers 3rd gen 305 to keep up with a 5.3 Sierra.
Re: hood clearance
how much do you think my 305 is putting down???
Engine: LS1/LQ4
First, you mentioned you have the stock HO intake. It's the same thing as the lo po LG4 intake, for what that's worth. Are you saying the car came with the VIN G L69 engine?
If so, it produced 190 net flywheel HP. You've got a slightly better cam, and the headers will help. With an open hood, the open element air cleaner will flow slightly better than the stock dual snorkel HO air cleaner, but in real world conditions, it will actually cost you power. Your exhaust, however, if 2.5", is a little smaller than the stock HO system, so the only way it could help is if it is mandrel bent and has a better flowing cat & muffler than stock.
I would guess that you're probably in the 220-250 net flywheel HP range. Probably closer to the lower number. Should run better than stock, but that 5.3 truck still has more power.
Re: hood clearance
first 5 vin on my car is 1g2fw
Re: hood clearance
H is my 8th digit
Also i just picked up a holley low profile intake i think i can bolt my qjet up to it..
Engine: 383 Carb
Transmission: 4L60
Re: hood clearance
That wasn't an H.O. then, just an LG4. About 165 HP when it was stock.
Re: hood clearance
oh wow... i thought it was a l69 it has 416 heads and it has 1.84/1.50 valves
oh and heres the intake i picked up
Some other pictures of the rebuild
brand new pistons also new valve springs/seals triton
91TTOPZ
Exterior Parts for Sale
09-20-2016 12:42 PM
