Stock air cleaner fit aftermarket carbs?
Car: 84Z28, 98Z28
Engine: roller 350, cc Qjet
Transmission: WCT5
As I think about an aftermarket carb, I was wondering if the stock L69 air cleaner housing fits on aftermarket carbs. Most of them seem a little longer front to back. For instance, the average dual inlet center-hung float type carb, they seem to be physically larger than most. I'd like to retain the stock appearance with dual snorker cold air system. thanks,
Pete
Pete
Re: Stock air cleaner fit aftermarket carbs?
JamesC
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
None of the OE air cleaners will fit over a dual feed Holley. I have an L69 air cleaner, and it doesn't work on top of any of the dual feed Holleys I've used. Not sure about the single feed Holleys or Edelbrock carbs though.
Car: 84Z28, 98Z28
Transmission: WCT5
OK, thanks for the info, I thought it looked like it would be tight.
86IROC112
09-07-2015 01:37 PM
86IROC112
08-17-2015 02:00 PM
