82 carbed z28 hood issues help plz?
Car: 84 Trans Am
Axle/Gears: 10 bolt 3.73 factory
with my intake and hood a 14inch aircleaner wont fit under the stock hood i would like to run a cold air intake sorta to the driver side battery slot.
I know they make them but cant find it its a 90 degree that fits ontop of a carb then u can run ur hose off of it to a air filter i cant fint one ive seen a 14inch duel setup but thats still to big.
has anyone else have the issue with the 82-84 hoods? what did u do?
if pics are needed i can take some anyhelp would be great thx
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Spectre makes "carb hats", but in order to fit under a stock hood, you need to use the reduced height version, which don't flow as well as the full height versions.
Also check out ramairbox.com.
BTW, drop base 14x3 air cleaners fit under a stock hood.
Car: 84 Trans Am
Re: 82 carbed z28 hood issues help plz?
http://www.edelbrock.com/automotive_...cc_elite.shtml
i have the 14 inch round filter and it it a drop base and it does not clear the prev owners cur a hole in the hood i got another hood but i need a solution.
the spectra 90 degree whould that plug up the motor to much and rob power?
PRO-FLOŽ 1000 SERIES REUSABLE AIR CLEANERS
http://www.edelbrock.com/automotive_...c_chrome.shtml
would this be good flowing filter i think it will fit
Car: 84 Trans Am
http://s556.photobucket.com/albums/s...=hoodissue.jpg
issue at hand
intake is a edelbrock performer rpm
issue at hand
theshackle
09-17-2020 08:26 AM
GVMV
08-16-2015 08:01 PM
