Rebuild manual for the Rochester E2SE Varajet
Car: 1983 camaro sport coupe
Engine: 2.8l v6 - stock motor
Transmission: NWC t-5
Axle/Gears: whatever came stock (?)
I found this rebuild/service manual for the Varajet carb used on 2.8 v6's. Here is a link to the PDF. Reason I am posting it is because I could not find this information on this site.
http://c777913.r13.cf2.rackcdn.com/r...2se_manual.pdf
Car: 1982 Firebird Base
Engine: 2.8L V6
Axle/Gears: Stock
Re: Rebuild manual for the Rochester E2SE Varajet
Great Find, this should be stickied. This was the only place I could find it where they didn't want money for a hard-copy.
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Just found this, thanks! Need to work on mine. Now if I could only find the info on modifying the linkage to open the butterflies more at WOT...
28, carb, carburator, carburetor, e2se, ii, jet, manual, rebuilt, rochester, rodchester, troubleshooting, v6, vara, varajet
