Replace my Q-Jet with a free Edelbrock?
Car: 1985 Trans Am
When I got my car, it came with the original Q-Jet. I rebuilt it last summer and it runs pretty well. It doesn't bog at all and it gets me pretty decent mileage on the highway. The problem is that the previous owner took all of the choke parts off of the carb at some point.
I like to be able to drive the car as much as I can, but if it's under 50 degrees it takes too long to warm up in the morning. I'm in Ontario, so it's below 50 degrees most of the year when I leave for work at 5:00 AM. I think I put less than 1000 miles on her this past summer.
My buddy has an Edelbrock 1405 that he'll give me for free. He bought it new two years ago and it never gave him any trouble. Should I take the free Edelbrock or try to source the Q-Jet parts?
My motor is a early 90's 350 from a 1-Ton pickup. It'll probably be replaced by a Blueprint 355 at some point in the next couple years.
1 Post
Car: 1985 Trans Am
Engine: LG4
Axle/Gears: 3.08
Re: Replace my Q-Jet with a free Edelbrock?
I don't think you're going to have the same glowing opinion of the Edelbrock carb. You can't do much better than the Q-jet for overall performance and getting good mpg. Or in your case kpg. You should be able to source the choke parts online. You most likely won't be able to walk down to your corner auto parts store and get them. Being a Canadian car, your Q-jet does not have the electronic feedback does it? You could swap the carbs and see how you like it. If things don't measure up, then swap it back. Just my two cents.
I love my qjet.
How far are you from Stoney Creek, Ontario?
There's Wildgoose Performance here, and they can do anything with a Qjet.....
Car: 1985 Trans Am
BTW your Camaro looks awesome. I'm hoping to have a similar end result with my T/A.
Car: 1982 T/A
Engine: 1973 400 Chevy
Transmission: 4 Speed Borg Warner
Axle/Gears: 3:23
I am sure you can scavenge all the missing choke parts from a local junk yard.
No do not do it keep the Q jet and fix the choke
Received 1,662 Likes
Putting that "free" Edlebrock POS on there will cost you AT LEAST 5 times as much if you buy NEW Q-Jet choke parts, maybe 50 - 100 times as much if you JY it. NOT ONLY will you have to buy a whole other distributor, BUT ALSO, deal with an intake manifold, fuel lines, throttle linkage, transmission TV cable stuff, air cleaner, TC lockup, ... the list just GOES ON. It's not ANYWHERE NEAR as simple as un-bolt and re-bolt.
Sell the other and use the money to shoo the buzzards off a CC Q-Jet carcass at yer local pick & pull.
If you have a free Edelbrock spend a $40 or so rebuild it clean it up and sell it for hundred hundred fifty
This site seems to have a lot of Quadrajet parts. The carbs are fairly easy to work on. The hardest part would be to get the flat linkage piece down the "well" and get the choke shaft engaged to it.
https://quadrajetparts.com/rochester...jet-c-128.html
Another source for QJet parts is https://cliffshighperformance.com/
True dat; been too long since I was up there. Almost a year. Sorry I didn't read the fine print.
The basic message remains the same... fix what ya got, before resorting to yank it off and takes yer chances.
I travel in that country fairly often. Last time I was up there, north of Timmins, I saw A BUNCH of junkyards all along my way. Even more near Hamilton right beside Toronto. Like ALL major metro areas in the Salt Belt, LOTS AND LOTS of totally rusted out wasted f***ed to the max car bodies with PERFECTLY GOOD engines. Shouldn't be too much of a challenge.
logikal6785
Exterior Parts for Sale
07-30-2006 10:06 AM
