Help! Part numbers vacuum system
Heeeelp,
I'm the new owner of a 1987 Z28, LG4, 305cui, 4BBL. It has the following emission house routing:
Obviousely, the previous owner wanted to clean up things a little bit.... and left several hoses cut.
I want to bring it back to original. I need the following parts:
I searched and searched and searched, until I've found this picture:
I searched for the correct parts, but I'm really not sure, if I'm right.
Does anybody know the correct part numbers???
Or does anybody sell a "complete used set"?
Thanks!
Thanks!
Car: 1986 CHEVROLET
Engine: 5.0L 305
Re: Help! Part numbers vacuum system
GM B-Body here to help, Glad to see someone is keeping the emissions systems. let you know part numbers tomorrow.
Car: 1986 CHEVROLET
Engine: 5.0L 305
Here is an eBay deal with everything you currently need and I will shortly upload all part numbers just in case anything fails
eBay Deal: https://www.ebay.com/itm/1988-Monte-...EAAOSwYeNa~ynO
Wow, thank you very very very very much! I just did an offer on ebay. I'm from germany, so shipping, duty and taxes will be another 40$. But let's see, if he accepts the offer.
Again, thank you very much !!!!!
Car: 1986 CHEVROLET
Engine: 5.0L 305
These Vapor Emissions Parts were searched for the 1987 Chevrolet Camaro 5.0L 305 VIN H (May fit other GM products)
#1 picture above. Vapor Canister Check Valve/ Thermal Vent Valve GM/ACDelco 25518739 or newer part number 214-563 (this part is quite hard to find NEW but no reason to hike up the prices sky high you sellers!) Was not able to find an after market seller that made this part.
#2 picture above. Bowl Vent Valve or Vapor Canister Purge Valve AIRTEX/WELLS 2M1002 original GM part number 17085929
#4 picture above. Vapor Canister Purge Solenoid Standard Motor Products CP221 original GM part number 1997162
#3 picture above. Vapor Canister Purge Valve (smaller of the two with one inlet and one outlet with one vacuum control port) Standard Motor Products CP100 Original GM Part Number 17087218 (CP100 is original match to the original part number 17087218 but I cannot find part CP100) Now I have not been able to figure out what the difference is between these two but the other two choices that come up when searching for parts for this car are Standard Motor Products CP109 for engines with FI? and Standard Motor Products CP106 for engines with CARB? probably you'll know.
There you go, Enjoy
There you go, Enjoy
Monsieur! YOU....ARE...AWESOME.
The only part I was correct with was 2M1002
Just got the ebay deal
Thank you, thank you, thank you!
My Slow Iroc-Z
01-16-2001 12:08 AM
