What cam for my TPI to Carb swap??
I am switching from tpi to carb in a month. I am going to use a Holley 700 double pump carb,Keith black 10-1 compression forget pistons, performer RPM intake, and some old camel hump heads from an old 302(getting mounting bracket for alternator.) What cam should I buy?
Bright red 87 GTA with 350 tuneport. Basic mods such as K&N filter, Flowmasters, Wells MAF, TPIS air foil, Accel 8.8mm plug wires with , Accel distributor cap and rotary buttons.Gutted cat. B&M Shift kit, 100HP shot Nitrous, soon to change over to carburator.
Car: 2002 SOM z28
High lift/ short duration dual pattern cam with about 110-112 LSA. Do you need to pass emmissions? If so, then a Comp cams 262 will pass. You can go a bit bigger with 1.6 roller rockers. The dual pattern will go good with a 100HP shot.
86IROC112
08-17-2015 02:00 PM
Sanjay
08-12-2015 03:41 PM
