What do u think of my redone rear panels?
Old Jul 26, 2007 | 07:25 PM
camarorsssss's Avatar
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
I was gonna have them done at a fabrication place, but they wanted $250 per panel and i just dont have the kind of money so i decided to try it myself. I decided to go with the same color as the carpet in the car and the bottom is the same material as my door panel. Let me know what you think
Attached Thumbnails What do u think of my redone rear panels?-camaro-2-016.jpg   What do u think of my redone rear panels?-camaro-2-017.jpg
Old Jul 27, 2007 | 06:32 AM
serpentineocean's Avatar
Car: 1986 Vert Z28
Engine: SuperCharged 350
Transmission: 5 Speed Manual
Re: What do u think of my redone rear panels?
You'd really have to show them installed. They look kinda funky right now. lol.
Here is what i did. I think they looked/worked great. But it was a major pain in my **** to do it at the time w/ the tools i had. I think i might try doing fiberglass next time.
FYI - The speaker is actually recessed so everything is flush w/ that mini arm-rest thing. Also, it was covered with black/charcole felt.
I never did get a pic w/ the grill on it. But it was nice.
Old Jul 27, 2007 | 10:20 AM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
So what was covering it originally? Mine had sewn vinyl, and looked fine but didn't match my new seats. I got some extra material that's on my seats and had the local upholstery cut and sew it together using the old cover as a template for $35. A can of contact cement to glue it back on and I was as good as new.
I've seen some older panels that looked like they had a mixture of fabrics layered on top of each other. If that's the case I can see where it would be expensive to invent the patterns needed to cover it in one piece.
Kevin D.
Old Jul 27, 2007 | 01:24 PM
Engine: Built ls1
Axle/Gears: 3:42
mine was a grey carpeted material, not vinyl. I wanted to go to a vinyl or leather material, but they wanted 200+ for each panel. The panels were shot, they had stains and some holes in them. So it was either i figure out how i can redo it myself or leave them ripped and stained. I had extra material left from when i redid my carpet, so i just used that. I tried using leather, but unless you have a sewing machine to do seams, its pretty much impossible without having wrinkles and bumps
The pictures dont really do them justice though, i think the flash is giving them that sparkly look, but they arent really like that.
Old Jul 27, 2007 | 02:30 PM
shr00m's Avatar
Sorry if you took it wrong, your's look good! I was infering that if you didn't have anything original with seams to pattern, it would be either impossible or really expensive to re-cover in vinyl.
I hear you on the flash.. My interior looks awesome until you flash it. Three things the same color look completely different depending on what they are made of.
Kevin D.
Old Jul 27, 2007 | 03:19 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
looks sharp man! congrats on the hard work.
Old Jul 27, 2007 | 03:32 PM
Engine: Built ls1
Axle/Gears: 3:42
Na dont sweat it shr00m, i didnt think you were knocking me, i was just giving a little more background so everyone knew where i was coming from and what i had to work with. You right with the vinyl/leather though, if you dont have the seams and have no way to make them, you are pretty much screwed, another reason i went with the carpet material
A little hot glue, prep work and time and you can do anything
Old Jul 28, 2007 | 10:35 AM
Engine: Built ls1
Axle/Gears: 3:42
here is a picture of them in the car
Attached Thumbnails What do u think of my redone rear panels?-camaro-2-020.jpg
Old Jul 28, 2007 | 10:38 AM
89N10GTA's Avatar
Car: 1989 GTA
Engine: 355 with Super Ram
Axle/Gears: 3.73 10 bolt with a True-trac
they look really good in car.
Old Jul 28, 2007 | 11:23 AM
Engine: Built ls1
Axle/Gears: 3:42
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
z28addict8490
Aug 7, 2015 08:48 PM
