(non factory) 3rd Gen Convertibles
#101
Re: (non factory) 3rd Gen Convertibles
X2 Try and remove the seals and the badge and write down VIN to document it for the future. I'd see if the yard would let you remove the top material and buy it and weren't the trunks different and header where front of top attaches. I 'd buy lots of parts to sell to Matrix convertible owners. Car looks really good...
I'd ask to buy whole car
#102
1 Post
Car: 1991 Z28, 1983 Z28, 1984 Z28
Axle/Gears: 4.10
I have a 1991 Z/28 convertible that I am in the process of rebuilding. I have the engine, transmission and rear axle out of the car at the moment, in the process of painting. I see where the re-enforcement rails were installed using large rivets. Is this how these frame rails were installed? Any help or info would be appreciated. Also how would I tell which company did the conversion on this car?
#103
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
John
#104
#105
I have an 89 iroc with an aftermarket top. It was done by a shop in NY state near Rochester. Am looking for pics of the frame without the top on. Thanks
#106
Car: 91 Firebird Convertible
Engine: 305 TBI
Transmission: Automatic
Is Buffalo Conversions from the Buffalo, NY area and do you have a interior picture of the top attachment brackets.
I just got a 88 Convertible and the top is shot. I have a 91 ASC which is much smoother set up.
I'm thinking of going just English style tonneau cover and put old top on shelf until a later date.
#107
Car: 1983 Gen three camaro
Engine: 350 dual quads
I just bought a 1983 z28 autoform conversion. no registration numbers in the door. Just trying to figure out how many 1983's are out there... I might buy another one soon. Mine is not matching numbers has a fresh build 350 small block with dual quads. Just gone over everything to get it on the road before snow flies in NE Ohio.
#108
The ASC tops are as follows: 86-88, 89 they were made wider and were improved, 90-91 same as 89, but with the headliner, 92, they changed the mounting brackets behind the doors.
John
#109
Yes, it was a Buffalo, NY converter. I am betting that they used the same top kit as several other converters. I have only seen one car from this converter, but do not have any detailed photos of it that are helpful.
#113
Car: 85 Z28 Vert
Engine: LG4 ENGINE 5.0 4BBL
Transmission: 700R 4SPD
Axle/Gears: 3:08
Hello! Its been awhile... 7 yrs to be exact... Instead of repling to a thread that is 7 yrs old, i thought it be apropriate to start a fresh here. I want to narrow down out of 4 manufactors to 1 company to determine who did my conversion. Please review the thread Information on my 85 Z28 convertible? HERE: https://www.thirdgen.org/forums/conv...my-85-z28.html
And post results here. We have narrowed it down to these 4 companys:
1. National Coach Engineering
2. Coach Builders Ltd: (1982)
3. AHA Manufacturing: (1983)
Or 4. Buffalo Conversion Corp: (1984)
Its been 6 (six) long years since we last researched this; and i still have the car and dont know who did the conversion. Thank you for your help.
#114
Engine: 305 TBI
My 1988 Firebird is a aftermarket conversion, and the mechanism looks very similar to the top system in this post I noticed my 91 factory backed ASC convertible looks like the process started as T Top. The exterior distance is 2 inches from the rubber edge of the windshield and header rubber. My 88 Firebird after market distance is 3 inches. My 88 trunk is 13 to 14' inches and my 92 heavy metal trunk is 24 inches deep.
#116
hello i have had mine for 20 years and i do not know who manufactured it. I t was sold new in Virginia they charged 6 thousand for the option.
#117
Hi, I am in New South Wales in Australia and purchased what I thought was an 87 Trans Am convertible 2 weeks ago. It has a 4 speed auto gearbox and a 305 TPI engine.
I am hoping to gain some knowledge from other owners as this is my first Pontiac and they are not the most common of cars in Australia.
The seller had it listed an 1987 model and the government registration papers say its an 87 model.
When I have checked the VIN code it indicates its an 86 model.
VIN is
1G2FW87F5GL253362
It was converted to RHD in 1994 in Queensland Australia and the engineers report says he believes it is an 86 model based on the fact it has a 4 belt pulley system not the single belt as found on the 87 model. He has it listed as a factory convertible, I am unsure if he has just assumed this or had other information.
It has a digital dash with the taco/revs counter in a gentle rounded curve not the wave style that most 86 models with the digital dash seem to have pictured.
I am trying to find out the following information.
1) Did any 86 models have the 87 dash with the rounded taco fitted.
2) From what I can find out it seems ASC only converted 3 1986 Trans Ams to convertibles as a trial for Pontiac. If this is the case how would I find out if it is an original car or if it was converted later on?
3) The 86 models i have seen so far all have a different set of rims to this car, again would that have been an option to have these fitted.
Thanking anyone who can help in advance.
Kind regards Pat
#118
Hi Pat,
1987 actually didn't come with the single belt serpentine setup.
https://www.thirdgen.org/forums/tech...t-routing.html
I am guessing the gauges are aftermarket digital. There was only one type of digital gauges from the factory. Take a picture of them and someone can probably identify them.
Looking at it, the rear spoiler setup is incorrect, it looks like it came off of a Camaro, but it's a really nice looking example. It probably has been repainted as I don't think the blue was offered without the silver ground effects, but I could be wrong on that.
Those rims are the "PW7" rims and were available in both 86 and 87 as an option.
#119
Hi Pat,
Cheers Pat
#120
Keep in mind that these cars were all converted to convertible. It would not be a stretch to get a convertible that was say rusted out, or damaged in some way, take those parts off and then convert either an existing T-top Firebird or a Camaro to a convertible.
Based on the few pictures you posted, that is what I think has happened. Someone converted the car. 1) the spoiler appears to be Camaro, and 2) in 1986 & 1987 the top of the doors at the rear there were extensions that you would see.
There is no difference to the dash from 1986 & 1987. The only difference that I am aware of is some of the early 1986 cars did not have the metric KM segments marked on the Speedo.
Cool car, I would drive it.
#122
Hi John, in regards to the trunks being the same from a Camaro to a Trans Am. I have an 86 Trans Am and a few people have commented that the spoiler looks like a Camaro rather than a trans am. I am wondering if you know whether you know if this would be the case for an 86 model, perhaps someone has just substituted a trunk they had for the original.
Regards Pat
Regards Pat
EP90266 (05-01-2020)
#123
For the 86-87 Firebirds The caps on the quarter panels are different too...
This is an 89, all of the firebirds from 1986-1989 used this type of setup. Actually the middle wing is a stock spoiler from a base Firebird with the ends cut off. The caps on top of the quarter panels are very different. THe picture below does not show the correct 3rd brake light. I do not have time to find a better pic right now.
There is a chance that your car may have been damaged, and they could only find Camaro pieces to put them on the car. Very possible.
Look at the Left door jamb, there should be an ASC sticker there.
#125
Does your car have the ASC sticker on the Left door jamb?
John
John
#128
Car: '90 IROC Convertible
Engine: 305 TPI LB9
Axle/Gears: 3.23 Disc Brake LSD
#129
I'm just jumping in here after I registered a moment ago.
I just bought a '82 Pontiac Firebird convertible with a V6 automatic.
Here are some photos from it.
From what I heard is that the V6 is rarer then the V8.
#130
Diante, Great looking car!! Appears to be a Hi-Line convertible.
Just as a note to everyone, This thread was really not intended to be a show & Tell. If you could please tell us who did the conversion, that would be great!
#132
Engine: 305 TPI LB9
#134
#135
I have a feeling I will have to start over with a new thread sometimes in the future....
#136
Car: 1987 Z28 Vert Special Edition
Engine: 305 TPI LB9
#138
John
#139
No one knows the answer to that and it is lost to history. Matrix3 did their own conversions and also did conversion vans and a few other conversions. An interesting one was on the Nissan pickups to make them an SUV. Based on the number of survivors of Matrix3 survivors compared to other convertibles of the era with known build counts, I would estimate that they built about 50 to 75 f-body convertibles per year from '84-86.
#140
Car: 1984 camaro z28 convertible
#141
My opinion: Same as a same year/condition/optioned hardtop Camaro/Firebird. They are not worth more because many people don't consider them "factory correct", but not worth less, because they are well built convertibles built to a "factory correct" quality.
#142
#144
#145
Car: Z28 roadster ACC
Engine: LG4
Hello everybody; Please excuse my poor english. I live in France... I'm new here. I have a 1984 Z28 convertible from Amerian Custom Coachworks. It's mine since more than 20 years. If someone knows about those convertions...
#146
found this http://coachbuilt.com/bui/a/acc/acc.htm
#147
Engine: LG4
Thanks for those informations. I knew ACC was a limousine builder. There's no information about how many cars was build.
Here is the picture when it arrived at home in 1999, with an old beige vinyl top.
#148
As for numbers... Those are probably lost to time, unfortunately there were several builders who did convertible conversions on these cars, I would be surprised if it is over 100 as I think this is the first one I have seen a picture of. But that means nothing.
#149
Engine: LG4
I'm very surprised you'd never saw a picture of an ACC Camaro. It was a big compagny and in my mind, I thought that there was a lot of cars like mine...I'm going to take some pictures of details of construction.
Price is also a surprise: 20000$, It's the price of two Z28 in 1984...that's maybe the reason of the small numbers
