Undrilled nos front seatbelt covers?
1 Post
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
Just curious Did NOS seatbelt covers ever come without screw holes in them? Got ahold of these and the guy said they were new gm but the other new set I have had the holes drilled. Was this some kind of available option for perfect alignment on your car or an old aftermarket molding?
Car: 89 Iroc Convertible
Re: Undrilled nos front seatbelt covers?
I have several pairs of these and I've noticed that none of the holes are uniform.They don't line up with the ones that are currently on my convertible
Car: 1987 Z28 Vert.
Engine: LG4: ENGINE, GAS, 8 CYL, 5.0L, 4BBL
Transmission: MD8: 4 SPEED AUTO THM700R4
Axle/Gears: GU2: AXLE, REAR 2.73 RATIO
same here
Transmission: Pro-built 700R4
Where are you guys finding them in such great shape? I know myself and 1992 Trans Am are both looking for a nice set.
These parts were made by ASC. All of the original ones I’ve seen are all so random as far as the screw hole placement goes on these. It is my guess that the holes were drilled when they were installed on the car. They are concaved holes iirc.
Can you post pics of the under side of them?
Engine: 4++,350 & 305 CIs
Even the screws are sometimes different type from side to side, maybe that's one reason Pontiac held off offering a vert until things were a bit better.
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
I have always thought these were hand drilled to each car as the piece was put in place. What you are describing confirms it for me. Repetitive positions were not in ASC's toolbox.
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I noticed that the screw locations were completely different from side to side for the rear seat trim. My Right side has 2 more screws in it than my left, It was like the guy on the Right side of the car did not know what the guy on the left side of the car was doing. The quality on one side is slightly better for fit, than the other... It was one guy had enough coffee and the other just got covfefe...
ev305tpi
Interior Parts Wanted
07-14-2015 09:35 PM
stealtht/a
03-23-2015 01:15 PM
91interceptorZ
01-28-2014 02:39 PM
