great way to cool down your car
if you race alot like me and want to cool down your engine easily, first unplug your a/c (since you aren't suppose to have on at the racetrack). then turn your car key to run and have your a/c on max for about 5 minutes. this will turn on your electric fan and will cool off the water (can't remember what it is called) in your radiator. Then if you start your car it will circulate it throughout the engine. It works great, i do it all the time.
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Or you could tap into the relay so you can let the stock sytem work on its own or flip the fans on manually.
Car: 1991 Formula
um...for those of you who havent seen this.. KaleCo Auto
No offence dude, but read the tech articles or other posts before posting some rigged way to turn your fan on. It would be only slightly more effort to wire a switch up. Plus doing this will create "hot spots" in your engine watering system, wich could be very bad.
Car: 00 TA, 91 Formula, 89 RS
Car: 1988 IROC-Z
Engine: 355ci TPI WORKED TO THE BALLS!
Transmission: 700R4 T-56 coming
LMAO:sillylol: :sillylol: :sillylol: :sillylol: :sillylol: :sillylol: :sillylol: :sillylol:
db057
Aug 11, 2015 10:11 PM
