Fan doesnt work
Old Nov 22, 2002 | 11:17 PM
Imadude_134's Avatar
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
Fan doesnt work
I have a 91 Camaro RS with the stock single electric fan. My car keeps overheating and the fan isnt turning on, neither cycling nor with the ac. any thoughts on what might be wrong or what i should look at for problems? Might is be a sensor? which one? any thoughts would be greatly appreciated.
Old Nov 23, 2002 | 07:20 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Most likely you have a bad fan relay or a bad fan motor or a loss of 12 volts. Locate the fan relay unplug it and look at the plug and the relay pins. If they look burnt most likely the relay is the problem. With the fan relay unplugged you can jump the two large wires with a test jumper and the fan should run, even with the key off. If it does motor OK. If it does not check for 12 volts at one of the heavy wires. Also you can sustitute the blower motor relay for testing, they are the same thing. NAPA # for fan relay should be AR-279.
Old Nov 23, 2002 | 08:33 PM
Car: 1991 Camaro RS
Engine: L98 350 TPI
today, i tested a few things:
The fan motor works
The relay works
The temp sensor (on the intake manifold next to thermostat) gave resistance (not sure what it should be tho)
The next thing that im gunna try is the fuse for the fan and the power line from the relay. anything else i should try? thanks for ur time
Old Nov 23, 2002 | 08:38 PM
Car: 1991 Camaro RS
Engine: L98 350 TPI
hey, im gunna try that thing with jumping it. i hope that works. thanks for the idea
Old Nov 24, 2002 | 08:44 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
just because the relay click does not mean its good. The contacts could be bad. make sure you jump the two heavy wires DON'T short to one of the thinner ones. Use a heavy enough wire or a pair of needle nose pliers if you hold the wire and its too small a guage you'll get a nice burn. Those motors pull over 10 amp when they start.
Old Nov 25, 2002 | 11:50 PM
pandorafowler's Avatar
Car: `91 rs
Engine: 352 TPI
Transmission: TH700 R4
fan relay
Wher is the fan relay located at?
Old Nov 26, 2002 | 01:25 AM
Car: 1991 Camaro RS
Engine: L98 350 TPI
on the drivers side, near the firewall.
and i found out what was wrong with mine....
the plug that goes into the relay was loose, and thus it was a faulty connection. thanks for you help. I really appreciate it....:hail: :hail:
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
TA8487
Aug 16, 2015 12:21 PM
Leggman1
Aug 6, 2015 04:15 AM
