Any difference between 5.0 TBI RS radiator and 5.7L TPI radiator?
Old 08-24-2003, 04:59 PM
Damon's Avatar
Asking becuase it seems that the cooling problems on my wife's 92 5.0 TBI Camaro are at least partially due to a corroded (plugged?) radiator. I am going to replace it but I'd like to upgrade, if possible, due to planned futured mods. Is the radiator for a 350 TPI car (same year) any larger/more efficient than the 5.0 TBI radiator? Easy drop-in is the name of the game here. It's an automatic car, so I assume if the 350 TPI rad fits it will have the right connections in the right place for the tranny cooler lines.
Old 08-24-2003, 05:15 PM
Sleipnir's Avatar
well when you go to the store, if you get it from a chain store or whatever ask for the part numbers for both cars radiators, if their the same...well then their the same, if their different....well....
Old 08-27-2003, 03:18 PM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
I believe they are the same.
Old 08-30-2003, 07:15 PM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
Same. Just get an aluminum one instead of copper. Much much better. Like $140 at Napa. Modine. Sometimes the one for the 350 tpi's have optional ports for the oil cooler option. Some formulas had it, not sure about camaros. Same setup other than that though.
84z96L31vortec
08-20-2017 12:16 AM
Randomtask2
08-13-2015 01:57 AM
Sanjay
08-12-2015 03:41 PM
84z96L31vortec
08-10-2015 08:27 PM
Quick Reply: Any difference between 5.0 TBI RS radiator and 5.7L TPI radiator?
