tbc bypass
Old Sep 29, 2003 | 06:09 PM
screamingz28's Avatar
Car: 85 Z28
Engine: 305 LB9 TPI
Transmission: TH-700R4
tbc bypass
can someone tell me how to route the cooling lines to setup a throttle body coolant bypass? i have a 305 tpi engine. i know it cools the incoming air to the engine by making the plenum cooler as well as the throttle body, but would it effect the cooling properties of other engine components?
Old Sep 29, 2003 | 06:33 PM
MdFormula350's Avatar
https://www.thirdgen.org/newdesign/t...ntbypass.shtml
it was a very easy mod to do, and probably lowered the plenum and tb temps a few degrees and every little bit counts.
Welcome to TGO!
Old Oct 14, 2003 | 05:52 PM
Car: 85 Z28
Engine: 305 LB9 TPI
can someone show me a picture of thier tbc bypass?
Old Oct 14, 2003 | 08:43 PM
Old Oct 15, 2003 | 06:05 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
If you go to an auto parts store with a sample of the old size hose(I forget what it is)you can purchase a hose with a nice bend that will be long enough to go directly to the heater valve without the couplings MD shows. I usually log part numbers, must be age catching up.
Old Oct 15, 2003 | 08:59 AM
lol funny u should say that Danno, a few days after that pic the cooper slid out and i lost about 1 gallon of coolant
i went with the one single hose now.
Old Oct 17, 2003 | 07:54 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
I saw where that tensioner guage is! Shame on you, I thought you were 'da man.
Old Oct 18, 2003 | 01:03 AM
joshwilson3's Avatar
Old Oct 20, 2003 | 06:03 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Does not have to cold for that to happen. The right humidity and pressure difference it can happen at 70 degrees. It's unlikely but it's possible. Case in point is my one sportbike. Honda VTR-1000, 2 carbs 48mm inlets. They run the coolant through the carb bodys near the idle air passages. I bypassed it for testing and first it NEVER idled properly. Second, you could sit at a light in 80 degree temp and it would simply die. I ran into a Honda rep at a show and mentioned it and his first thought was that the idle air passages may have been icing. Hooked it back up and set it to 1200 rpm and it stays there after it warms up no matter what. I had my 89 5.7 TPI bypassed and it also seemed that the idle was a little unstable the longer it idled. Recently I did some major work and just put everything back to stock. It runs perfect, idles so smooth the tach needle never moves. Who knows?
$750 L98
Feb 1, 2025 02:25 PM
djmarch
May 8, 2016 11:32 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Formula8r89
Sep 22, 2015 04:24 PM
