need all the bolts for dual fans
Old Apr 17, 2004 | 02:32 PM
Trans_AM_88's Avatar
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
hey guys. i need every single bolt needed to mount dual electric fans to the car...top rad support, bottom support and the 3 bolts for each fan. can anyone direct me as to where i can get these bolts? i have no clue where to start.
Old Apr 18, 2004 | 02:16 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Go to a junkyard and steal all the bolts from 2 single fan cars.
Old Apr 18, 2004 | 05:10 PM
Engine: carbed L98
i really havent seen any electric fan cars in the junkyards around my area...and if i do theyre already gone
Old Apr 19, 2004 | 12:29 PM
Engine: carbed L98
anywhere else i can look? also...im not sure if i have all the pieces. all i have right now are the 2 fans, top support and the bottom piece. is that all i need?
Old May 30, 2004 | 02:54 PM
CamaroBoy88's Avatar
You can just go to a hardware store. The three bolts holding on each fan are M8-1.25 x 25mm, you'll also want to pick up washers for each bolt. As for the plastic piece at the bottom that the fans bolt to, I just used two bolts and nuts I had laying around the garage.
Old May 30, 2004 | 07:59 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
You can also use transmission pan bolts (700R4).. They have a little washer built into them and they're the right thread size..
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
krisner89
Oct 10, 2015 06:03 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
