Heats up, cools down
Hey guys, I have an 88 Camaro that has been acting odd. After about 25 minutes or less, it gets to 220 and if I constantly drive faster than 50 it will heat up more. But, if I sit in traffic it cools below 220. It has no airdam, and a 180 thermo just installed. It was worse with the 195 thermo. Is the radiator and airdam what's wrong? or is my water pump messed up?
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
Re: Heats up, cools down
Originally posted by GTA_fan
It has no airdam ... Is the radiator and airdam what's wrong?
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
I have some low ground effects on my bird, I do have an air dam, but I fliped it backwards to get more air. Is this foolish???
I also dont have the sides to my birds air damn (pun intended).
Well, I'm still waiting to get the airdam, and I mean it's like 100 degrees out here. With this heat, the car is running 230-240 going 35 in 5th gear and in neutral going downhill. I don't think I can drive it like this for any trips longer than 15-20 minutes. I hope this isn't injuring my engine, I need it for school.
well, I ordered the part off ebay for 37 $ including shipping. As for the overheating w/out the airdam, I just take short trips so the car never even gets to 190. I decided that since one day i drove it until it got to 240, that i would never drive it at that temp again because it's not worth risking a ruined motor over a missing piece of plastic. I'll let you guys know if the airdam alone fixes the problem. If things keep up, I'll check into the radiator, water pump, etc.
-rob
-rob
