need help!!!
Old Dec 20, 2004 | 03:27 PM
MoroteZ28's Avatar
Car: 1991 pontiac firebird
Engine: 305 V8 flo-pro exhaust
Transmission: automatic 700r4 4speed
Axle/Gears: stock 2.73's :(
need help!!!
alright my car has been leakin antifreeze and i checked the hoses n they were on pretty tight and my car has started smokin antifreeze after driving the car for like 3 minutes i just put in new thermastat and gasket and i thought it was fixed and im driving down to get my exhaust done and at the next light its smoking like hell what could this be?? also i dont have my airdamn plastic on could this also be making it over heat?? i havent had it on for a while tho and this just started happening like the other night
Old Dec 20, 2004 | 04:31 PM
MoroteZ28's Avatar
lol nvm i do have the air dam but its crakced in the middle of it so could that be an issue?? plz help!!
Old Dec 22, 2004 | 09:21 AM
10gunman's Avatar
Car: 85 Camaro Z-28
Engine: v8 305 4bbl carb
Transmission: t-5
no I don't think the air dam has anything to do with your problem I think you didn't tight enough the bolts when you changed the thermostat cause that is what happened to me when I changed my thermostat try to tight the bolts again and if possible try to get a new gasket when you do go from one bolt to the other don't tighten one and then the other do it simultaniusly like make a couple of turns on one bolt and then the other like that both at the same time you'll get a better result that is what I did on mine when I changed it like I said before the same problem happened to me hope this helps.
Old Dec 22, 2004 | 09:49 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
If your car's "smoking" because it's boiling over (at the reservoir or radiator) then it's getting too hot and your air dam will definitely help. Also check your radiator fans and make sure they're coming on.
If it overheated immediately after changing the t-stat you may have had air trapped behind it not allowing coolant to reach it to open it. This is a very common, short-term problem when changing one out. As soon as the t-stat warms up enough to open, it should work fine. Some recommend drilling some small holes in the new t-stat to prevent this. You can search to find out more on drilling one.
If it's leaking somewhere-find out where and fix that.
