Dual Electric Fans Problem
Old Oct 14, 2005 | 10:44 AM
Zokal's Avatar
Car: 1989 Firebird Formula
Engine: Chevy TPI 350
Transmission: A/T 700 R4
One day I left my car running for a long time, then all of a sudden it ran hot. Come to find out, my fans were not coming on. When I turn on the A/C, you can hear the A/C working, but the fans will not come on. I checked the fuse, and it is ok. So what do you think can be causing my fans not to work? (If it's the relay, where is it located?) Other than the relay, what could it be?
Old Oct 14, 2005 | 06:57 PM
Zokal's Avatar
Anyone, Help! I know it gots to be simple.
Old Oct 17, 2005 | 11:13 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
I had a problem with the fans not coming on and it was the relay.
Old Oct 18, 2005 | 10:25 AM
scott 87z28's Avatar
fans
what fan is controlled by the ecm and what fan is controlled by the temp switch??
drivers side or passenger side?
thanks
Scott
Old Oct 18, 2005 | 10:40 AM
Zokal's Avatar
Would the temp switch have something to do with the temp gauge malfunctioning? When you crank the car, the gauge (needle) jumps to the other end.
Old Oct 19, 2005 | 05:12 PM
azvolfan's Avatar
The fan switch to which I think you are refering would have nothing to do with the gauge. The temp sensor is located at the front of the intake manifold right next to the thermostat housing.
Old Oct 19, 2005 | 05:47 PM
Zokal's Avatar
I tried looking for the fan relay once, but could never find it. Could you post a pic' of where it is located or give a good detailed description of where I can find it at? Thanks.
Old Oct 20, 2005 | 03:16 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Fan relays are on the pass side of the car, one is on the fender and one is next to the radiator.
Gauge sensor is on the drivers side block between cylinders 1 and 3 and the gauge always pegs when you start up the car.
Old Oct 20, 2005 | 04:34 PM
Zokal's Avatar
Great Pics. I appreciate it.
Old Nov 19, 2005 | 06:30 AM
mrdezman's Avatar
Car: 89 iroc/ 88 supra targa top
Engine: 350 tpi / 7mge
Transmission: 700r /
cooling fans run constantly
my cooling fans run when i turn the key, with only the accessory switch on. Researched some wires and found a red wire running from the starter not connected to anything. could this be my problem. Should this wire be on the positive side of the battery or should it be grounded?Hit me back.
RazorN8
Jan 7, 2022 11:44 AM
krisner89
Oct 10, 2015 06:03 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
