Water PUmp
Water PUmp
I have an 88 Iroc with a 305. My water pump pulley is sloppy so the belt is squeeking and the pulley is growling. My water pump isn't leaking yet. Do I need to replace the water pump now or is it ok to drive for a little while.
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Put some form of stethoscope on the pump and listen. If you hear it coming from the pump, then yes, replace it.
evilstuie
Jan 9, 2020 08:29 PM
Dialed_In
Aug 20, 2015 01:45 PM
