Reverse vs. Std. rotation water pump Pros/Cons
Old Sep 18, 2006 | 12:43 PM
Anniversary-Z-man's Avatar
Car: 1992 25th Anniversary Z28
Engine: 6.3L - 383
Transmission: 700R4; Vig 3200
In my on going search for a pulley system for my '92 Z, I have had zero luck finding a low mount system that incorporates ONLY the crank, wp, ps, and alt....where the alt would mount on the passenger's side.
Anyways, this seems to be mainly due to the fact that the water pump is reverse rotation. I know if I had a std. rotation pump I'd have no worries.
I have a brand new polished Stewart stage 2 pump right now, that I'm hesitant to get rid of, but I also have a Miniram that I made a custom 3.5" intake for instead of 4" like I wanted due to space limitations of the the pulleys, and the damn thermo. housing. If I was able to get the low mount pulley system to work, then I would have the space to get a different thermo. housing, and also go with a 4" intake and get rid of the AC delete pulley.
Anyways....does anyone know the pros/cons of the reverse pump vs. the standard rotation one? I'm curious if it was developed mainly for ease of serpentine belt routing or if there are more reasons?
Thanks,
- Joel
Old Sep 18, 2006 | 01:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It's only for belt routing. With V belts, the water pump turns the same direction as the crank. With a serpentine belt it turns in the opposite direction.
Old Sep 30, 2006 | 12:54 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
you might be able to send your waterpump off and get the impeller changed?
cost a few bucks, but same some hassle.
evilstuie
Jan 9, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
MoJoe
Sep 24, 2015 09:12 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
