Temp Guage not working
Car: 1989 Pontiac Trans AM GTA
I just bought an 89 GTA and all of the gauges work except the temp. which is the one i want to work the most. When i got the car it would stay at 0 degrees then it would sometime peg, and when i hit rough road it would start to swing back and forth, now it stopped bouncing and remains at zero. I am not sure where the sensor for it is located. i did find a loose wire but not sure if thats it, any information as to were it is located would be great, pictures would help alot more tho, the engine is a 350 TPI btw.thanks
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
The sending unit for the temp gauge is in the driver's side head between the 1st and 3rd spark plugs,actually just below.Should be a single green lead going to it.It sounds like your problem may just be a loose connection.
Car: 1985 Camaro Z28/1989 Pontiac Trans Am GTA
Engine: 305 tpi/350tpi
its the green wire hanging under the car and needs to be connected to the semsor he is telling you about!.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
if the guage is bouncing around i would almost think that the sending unit is bad, when i disconect mine the guage just sits at 0
Car: 1987 Iroc Z28
Engine: 350 HSR
Axle/Gears: 3.27 Borg Warner 9bolt
I just replaced the sensor in my car to no avail. If the wire is ok and the sensor has been replaced try taking off the cluster cover and touch the temp needle. That is what i just went thru the past weekend and i did all above then I touched the needle and the darn thing just woke up.
Ghettobird52
Jul 5, 2024 11:18 PM
