hard plastic lines that go to heater control
Old Apr 9, 2007 | 05:49 PM
dwint's Avatar
Car: 88iroc
Engine: 355 blueprint engine
Transmission: raptor built 700r4
Axle/Gears: 373
i have a 88 iroc,put in a new engine and the so called mechanic never put the lines on.i no longer have the heater control valve so where can i put these lines in order for my flapper door to work?are they both vacuum?one is straight and one has a elbow.i have been on four different camaro sites and can not get the answer i am looking for.
Old Apr 12, 2007 | 06:06 AM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
Re: hard plastic lines that go to heater control
I believe the one with the elbow should go to a vacuum source on the engine and the straight one was for the heater valve. connect the elbow to a vacuum port on the engine and you can plug the straight one.
Old Apr 22, 2007 | 11:22 PM
likeistoleit's Avatar
Car: 87 Iroc
Transmission: Tremec Tko
Hard line with elbow goes to port on pass. side of plenum, straight one goes to heater valve.
1992 Trans Am
May 10, 2023 07:19 PM
The_Phoenix
Feb 4, 2016 07:10 AM
lakeffect2
Aug 23, 2015 08:44 AM
