heater problem
Old Dec 15, 2007 | 04:37 PM
laynlowz's Avatar
Car: 85 camaro
heater problem
this is for my 99 s10
it has 4 fan speeds.the first 3 work but when i put it on the highest the fan just shuts off.
i changed the relay,resistor and the heater control and still nothing
any ideas?
i heard about something in behind the deck,its some kinda relay or something but i dont know what its called
ive tried s10 sites but no help really there
Old Dec 16, 2007 | 07:27 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
Re: heater problem
well, sounds like your switch to me but I'm no expert. before you real far you could check the ground. used to have an 86 firebird & the blower just quit; repair shop ran a new ground from fan box to the sheet metal under the hood and the fan started working. same car and headlight motor also went out. a buddy ran a new ground & the fan moter started working again. probably not your problem but might try it and eliminate a semi-bad ground wire from the problem set.
Old Dec 17, 2007 | 12:00 AM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Re: heater problem
The high speed blower position uses a different 12V source than the three lower speeds. Start at your blower motor, you should have two connections, one black (which is the ground) and the other is Purple? (purple on camaros) and trace back to the blower motor relay in the engine compartment. You should find a RED or ORANGE wire on the relay. Trace this in the engine compartment. Most likely the fusible link in the red wire is blown.
One way to check is to pull the blower motor relay and put a voltmeter between the terminal for the red wire and ground. It should be hot all the time. If its dead then the link is gone or the wire is bad from the relay back to the link.
Let us know what you find...
Dave
Old Dec 17, 2007 | 12:48 AM
OS3Fleming's Avatar
Car: 1984 Camaro Z28
Engine: 357 SBC
Re: heater problem
I second 82 crossfire Z28. I am relpacing one tomorrow on my 84. I have all other speeds but no high. When It started I had none.
I wired the motor to the bat and it ran. So then I replaced the switch and it worked no high though, Ordered the part SUN and will put it in tomorrow.
Old Dec 18, 2007 | 11:48 PM
laynlowz's Avatar
Car: 85 camaro
Re: heater problem
on the back of the fan speed switch there are 4 wires pluggin into it.does each wire act as a power to each speed?
Old Dec 21, 2007 | 12:12 AM
Re: heater problem
Take a look at the wire diagram at this link...
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
you want to look at Fig. 21, in the top right side.
Three of the four wires power the blower motor at Low, M1 and M2 speeds. The fourth wire energizes the blower motor relay for HI speed. The relay contact provides power to the blower motor at high speed via a direct connection to the battery/alternator.
Hope this helps
Dave
Old Dec 21, 2007 | 07:34 AM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
Re: heater problem
Like 82 and OS3 said check the relay. You can look at the switch as long as you want unless you want to fix your issue. You will MORE THAN likely find a bad RELAY
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
