So you guys want a bolt in all aluminum 3 core radiator?
Old 06-09-2016, 06:15 AM
  #551
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Re: So you guys want a bolt in all aluminum 3 core radiator?
Originally Posted by bwmcam
Sorry, try it now
any problems with the radiator?
Old 06-09-2016, 09:27 AM
  #552
bwmcam's Avatar
Car: 1987 IROC Camaro T-Tops Rule!
Transmission: 700r4 Pro Built / 2600 vigilante tc
No issues, I live in Houston Tx, it cools it better than the stock radiator in the summer. Sitting in traffic with the fans on it brings it down to 185, Once I start driving it brings it down to ~180, in 90 degree humid Houston weather. I thought the extra thickness of the radiator might pose a problem, but I have not had an issue. It was well worth the $$.
Old 07-09-2016, 09:39 AM
  #553
no new tires's Avatar
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
So, Champion 3 row : yay OR NAY?
On second thought, ill just get the 2 core.
Old 07-13-2016, 12:31 AM
  #554
Pat Hall's Avatar
Hey if any of you guys are interested, I've got a brand new, Champion 3-core (CC951), that's never been installed or run, that I'd be willing to sell for $145 shipped to anywhere in the lower 48. I checked Ebay and my asking price is like 20 bucks cheaper than the cheapest listing on there. It's in perfect condition. Just never used it and ended up going with a different radiator. Anyone who's interested, feel free to send me a PM on here or you can email me at Nosferatu6979@msn.com. Thanks! P.S. I have some pics of it if you'd like to see it before deciding.
Old 08-23-2017, 12:47 PM
  #555
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Anybody put a Champion 3 or 2 core in lately?
My rad started leaking so its time to get a new one. Either grab the plastic cheapo $80 spectra, or upgrade a bit. But if Im paying twice as much for the Champion 2/3 core, I expect it to not have any issues.
So, lets hear from ya.
Old 01-21-2018, 12:32 PM
  #556
sonic1971's Avatar
Hi Gang, I just bought the champion 3 core with the aluminium shroud and am having a problem getting it to fit. Issue isn't the rubber supports and I know to shave them down. IT is the piece that sits on top and holds it all together. In my 89 TPI 305 the piece that holds in together is slightly curved and narrows in the middle making it tip up in the back regardless of what I do with the mounts. Is there a custom piece that you can buy that fits properly? Thanks for any help you can provide
Old 06-27-2018, 05:09 PM
  #557
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Anybody tried the Eastwood triflow? https://www.eastwood.com/triflow
Old 06-27-2018, 06:18 PM
  #558
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
I have not, but I've been wondering about them. It would certainly increase time in the radiator, but doesn't that restrict flow?
Old 07-11-2018, 10:09 AM
  #559
Camarothatcould's Avatar
Car: IROC/F250 7.3
Engine: LS12367
Transmission: Autos
Originally Posted by robg91z
Anyone ever heard or tried out northern radiators? I saw them on ebay says for third gen camaros. Heres the item number on ebay 200969529017
Just installed one last night as my 30 year old oe unit blew. While it's a direct bolt in, it fit ok. I just need to trim down the plastic upper support so the fans will line up again with their mount
Old 04-12-2019, 09:28 AM
  #560
rushtk's Avatar
Car: Teal 92 Z28
Engine: 5.7
I know this thread is about the fans, which I am going to follow the advice given here but I was also wondering about the water pump. From reading around it is stated that my OE is pulling over 10 HP away from my motor (92 Z28 350 with 94k miles) what are you guys doing for your? Thank You
Old 04-12-2019, 11:34 AM
  #561
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
This thread is about Radiators, Electric water pumps will use the least amount of HP but For a daily driver I would stick with a well known Manufacture and use a standard belt driven unit.
Old 04-16-2019, 10:09 AM
  #562
TGO Supporter/Moderator
anesthes's Avatar
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
Nearly 10 years running my champion/victory radiator on my 412" blown SBC.
No issues.
-- Joe
Old 09-11-2020, 10:42 AM
  #563
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
Will this 3 core rad fit my 88 Firebird Formula 350?
Correct holes for the trans cooling lines?
Will the twin fan set up fit?
Specifictions:
Core size approx : 26.2"*16.9"*2" (665mm*430mm*52mm) --- 3 ROW
Overall size approx : 31"*18.7"*2.76" (785mm*475mm*70mm)
Upper inlet: 1.25" (32mm)
Lower outlet: 1.5" (38mm)
Core and Tank: All Aluminum
It's not that expensive, and available in my country...
Thanks!!
Old 09-12-2020, 03:50 AM
  #564
Brand for the above rad is : GPI Racing, made in China...
Old 09-12-2020, 09:19 PM
  #565
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
haven't heard of that brand, so I apologize I can't give it any comments.
Old 09-13-2020, 12:54 PM
  #566
Specifictions:
Thanks!!
How do I close that small hole half way down the radiator cap ??
There's no senor or anything on the existing radiator, although I can see the hole is closed one way or another..
Old 09-13-2020, 04:29 PM
  #567
BLACK Z's Avatar
Car: 86 Z28
That goes to your over flow tank.
Old 09-13-2020, 11:16 PM
  #568
I know, but I mean the hole halfway the rad...
The transline holes are closed with plastic caps, but the hole in the middle is just open, should be some sort of level plug..??
Old 09-14-2020, 07:42 PM
  #569
BLACK Z's Avatar
Car: 86 Z28
Gotcha I am not sure I'd have to see it in person.
Old 09-15-2020, 11:02 AM
  #570
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
That is likely for a low coolant sensor
Old 09-15-2020, 11:44 AM
  #571
Right, my thoughts as well, but my car doesn't have that sensor, how do I close it on the new radiator ?
Old 09-15-2020, 03:40 PM
  #572
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Pipe plug? I am not sure what th thread is, or it may come with the plug
Old 09-15-2020, 08:38 PM
  #573
BLACK Z's Avatar
Car: 86 Z28
It seems like it would be for a sensor, but it doesn't seem to be the correct size but maybe it's the picture. Id find a plug and use sealant if it goes into the water jacket.
Old 10-07-2020, 11:24 AM
  #574
I found an aluminum welder near me, he welded an aluminum plug on it for small money.....
Old 10-07-2020, 11:25 AM
  #575
So now for the draincock, I see you all use brass ones in your aluminum rads, no problems?
Old 06-22-2023, 05:21 PM
  #576
slow305's Avatar
Car: 1982 Z28
Engine: LC9
Transmission: AR5
A three-year bump! Installed the Champion three-row radiator on my LS-swapped 1982 Camaro, and no issues other than what has been mentioned about trimming the upper and lower rubber snubbers (or make your own). OEM upper shroud and single fan went in perfectly.
Attached Thumbnails So you guys want a bolt in all aluminum 3 core radiator?-pxl_20230612_221658288.mp.jpg
BLACK Z (06-22-2023)
Old 06-22-2023, 07:02 PM
  #577
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
Holy crap, hard to imagine a post I made 14 years ago has almost a quarter million views lol
Old 06-22-2023, 09:35 PM
  #578
slow305's Avatar
Car: 1982 Z28
Engine: LC9
Transmission: AR5
You need to cash in like a YouTube or Tik Tok influencer!
Pat
Old 09-23-2023, 12:04 PM
  #579
Pro
Pro's Avatar
Car: 1992 Z28 and 1995 Silverado
Engine: 5.7 TPI and 5.7 TBI to TPI convert
Transmission: 700R4 and 4l60E
Axle/Gears: G80 3.23 and open 3.42
I'm still looking for that perfect radiator. The one where its a direct bolt in, 3 row or better, and nothing has to be trimmed. This car doesnt have any body modifications, holes drilled into the metal, plastic pieces trimmed, etc, and to have something that bolts right up would be special.
Old 09-23-2023, 08:59 PM
  #580
KITT1983's Avatar
Originally Posted by Pro
I'm still looking for that perfect radiator. The one where its a direct bolt in, 3 core or better, and nothing has to be trimmed. This car doesnt have any body modifications, holes drilled into the metal, plastic pieces trimmed, etc, and to have something that bolts right up would be special.
champion or be cool
IROCZman15 (09-24-2023)
skinny z
Aftermarket Product Review
02-02-2015 01:58 PM
gta324
08-11-2011 05:36 AM
firbird
Fabrication
40
08-30-2010 02:31 PM
gta324
Fabrication
06-23-2010 03:11 PM
FireHwk
07-28-2009 12:13 PM
Quick Reply: So you guys want a bolt in all aluminum 3 core radiator?
