Blow Motor-AC side works, but Economy side does not
Old Mar 14, 2010 | 09:05 PM
cxxm's Avatar
Car: 1984 Trans Am
Engine: 305 L69 (E4ME)
Transmission: NWC T5 1352-072
Axle/Gears: 3.73 (6HS)
84 Trans Am. I was driving down the road with the heater on and the blow motor stopped working. The blow motor works under all the air conditioning settings, but when I move it over to the economy (vent, heater, defrost) settings, I only hear a click and the fan stops working. I put a test light on it, under the ac settings with the fan working the test light comes on, but it is a very dull light. When I move it over to economy the test light is very bright, but the fan stops moving. Any ideas what is causing this problem?
Old Mar 14, 2010 | 11:50 PM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Re: Blow Motor-AC side works, but Economy side does not
Someone else will come along with a better answer but it sounds to me like the HVAC controls have just gone bad.
Good luck
Alex
Old Mar 20, 2010 | 10:35 AM
cxxm's Avatar
Car: 1984 Trans Am
Turns out just a bad ground wire. I took off the black ground wire at the back of the blow motor. Then I hooked up a wire to the back of the blow motor and grounded it straight to the chassis and the fan started moving.
The strange part is that my fan has 4 speeds (Lo-Med-MedHi-Hi). On the AC side all 4 speeds work. On the Economy side, I'm only getting 3 speeds (Lo-Med-MedHi) to work no Hi speed. I swapped out the fan switch and the relay under the hood, but no luck.
It would seem strange to have it only work 3 speeds from the factory. Does everyone's heater (Economy side) work on all 4 speeds?
Ghettobird52
Jul 5, 2024 11:18 PM
Terrell351
Jun 13, 2021 01:13 PM
jackhammer
Aug 15, 2015 10:04 PM
Elliswon
Aug 10, 2015 12:33 PM
Fronzizzle
Aug 9, 2015 01:15 PM
