Overheating Issue, help please!
Old Jun 25, 2010 | 10:46 PM
t-ray10's Avatar
Car: 1992 Camaro RS, 2012 ZL1 on order
Engine: 5.0 305, 6.2 Liter LSA SC
Transmission: T5, TR6060
Axle/Gears: stock, 3.73
I have a 92 RS with the 5.0 305. It has been overheating for about 2 months now. I have replaced the coolant, put in a 180 degree thermostat, flushed the system, replaced sensors, replaced water pump, and cleaned the radiator but it still overheats like crazy. The fan also runs all the time so that cannot be an issue. It is not burning oil and there is no coolant in the oil. Can anyone help me? Thanks
Old Jun 25, 2010 | 10:55 PM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
Re: Overheating Issue, help please!
have it tested to see if the exhaust is blowing up thru the exhaust for possible head gasket or warped head.
Old Jun 25, 2010 | 10:57 PM
cxxm's Avatar
Car: 1984 Trans Am
Engine: 305 L69 (E4ME)
Transmission: NWC T5 1352-072
Axle/Gears: 3.73 (6HS)
My cooling problem was from the broken/missing spoiler underneath the radiator. It deflects air up into the radiator. It made a big difference for me.
Old Jun 25, 2010 | 10:59 PM
t-ray10's Avatar
Okay, would the car run rough if the heads were distorted?
Car: 90 formula
Transmission: auto
the air dam. yeah i always have to mess with mine.
and it could, or it could run perfect and still be warped. my ramcharger ran like a dream but had a blow headgasket
Old Jun 25, 2010 | 11:07 PM
t-ray10's Avatar
Ya, I don't think mine has an air dam, it just has the intake next to the a/c radiator and coolant radiator. But, like I said, it has only been doing it for two months. I will definitely check the heads though.
Old Jun 25, 2010 | 11:45 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
You need the air dam. Is it overheating when you drive at low speed around town, or just when driving at higher speeds? If the fan is running fast enough it should stay cool enough at low speed.
Old Jun 26, 2010 | 10:48 AM
Car: 90 formula
Transmission: auto
get pics on here of ur air dam
Old Jun 26, 2010 | 02:21 PM
t-ray10's Avatar
I have had the car for a year and a half, i have never had the air dam, and it just started to overheat. It is probably a good thing to look into but will not solve the problem at this point. How do you test your heads to see if they are damaged or distorted?
Old Jun 26, 2010 | 02:45 PM
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
You definitely need an air dam! Otherwise there is no cool air to cool down the coolant in the radiator. I bought my car from a Chevy dealer in town, and it had no Air Dam, no Thermostat, and a bad radiator. I had to replace all 3 items. But for the Air Dam, I just made one work from off a sunfire, but it works, and looks good too.
Here's a pic of my GTA with my make shift air dam.
Old Jun 26, 2010 | 03:09 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Hate to repeat myself, but
Old Jun 26, 2010 | 03:19 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
OOPS, I forgot to ask. Is the fan turning like REALLY fast, or is it possible its lost some of its power running all the time? I also assume you got the reverse rotation water pump when you replaced it? Again, when you drive slow around town does it overheat? Or will it overheat sitting still?
Old Jun 26, 2010 | 03:27 PM
Car: 90 formula
Transmission: auto
he would be so surprised of what it does. before i re ghetto rigged mine it cooled off okay but now it cools off alot faster.
Old Jun 26, 2010 | 03:54 PM
t-ray10's Avatar
I took a look and I do have an air dam. And i did buy the correct water pump. It overheats all the time. and the fan moves quite well, i tested the voltage and it was great. I am really leaning towards the heads. Is there any way to test them without tearing into them?
Old Jun 26, 2010 | 10:04 PM
Car: 90 formula
Transmission: auto
i forget what kind of test it is that you put where the radiator cap is and it will tell you if exhaust is coming up thru your coolant but you can also do a compression test to make sure they are sealed.
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
