cooling fan question
Old Jun 29, 2010 | 11:18 PM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
not getting power to my fans but fuse is fine and puts out power. before i tear into it tomorrow and make a switch is there a relay or anything between the the fuse and the fan it self? its not the. ground is fine.
Old Jun 30, 2010 | 04:19 AM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Re: cooling fan question
There is a relay on the passenger side of the radiator. Dont just toss in a switch because without a relay you will burn it up.
Old Jun 30, 2010 | 06:57 AM
Car: 90 formula
Transmission: auto
i figured there was some where but it looks as if somebody removed me before me.
Old Jun 30, 2010 | 10:45 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
you have a single fan on the car?
Relay locations are (depending on car):
1. Drivers Side Firewall near the Fuel pump Relay
2. Pass Side Fender next to overflow resevoir
3. next to radiator on pass side.
Old Jun 30, 2010 | 11:30 AM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
If your fan works when you switch on the AC, your relay is fine. Often the fan switch that triggers the relay is the problem
Old Jun 30, 2010 | 11:38 AM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
If you're sure you don't want to try and fix the stock fan system and are determined to put in a switch for manual operation look here https://www.thirdgen.org/forums/cool...wont-turn.html and go to NINA's post for diagrams of safe ways towire it up
Old Jun 30, 2010 | 01:38 PM
Car: 90 formula
Transmission: auto
i fixxed it and the ac fan is working on the same circuit with the cooling fan so they both lost voltage at the same time.i rewired everything from the fans to the fuse box and a ghetto relay. running smooth again.
Old Jun 30, 2010 | 04:05 PM
pbtrilogy's Avatar
Car: 1985 Z
Engine: 89 305 TPI
Transmission: 700-R4
Axle/Gears: OSD 10 bolt/ 3.42
I have a single fan and have both # 1 and # 2...does this seem normal?
Old Jun 30, 2010 | 05:02 PM
Zepher's Avatar
Do they both control the 1 fan?
On the firewall, there can be up to 3 relays. I am not at home to look at my manuals, but 1 would be fuel pump, 1 would be maf, and the other would be the fan, or one of the fans.
On my 88 my relays are in position 2 and 3.
On my friends 91 V6 Camaro with a single fan it was on the firewall.
chazman
Aug 28, 2018 03:25 PM
krisner89
Oct 10, 2015 06:03 AM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Aug 6, 2015 04:15 AM
