2 or 3core?
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Axle/Gears: disk rear, 10bolt.
2 or 3core?
i am currently running the single core aluminum radiator with the plastic sides. and the rs single fan (big fan) now my car has seen 210-220 a few times. i just dont what to over heat. the motor is a mild 350, 160 t-stat but the headders i have keep it hot in the engine bay, i am currently lookin in the the champion 2 core or 3 but dont know what one to get.
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
Re: 2 or 3core?
If you can get the 3 core to fit in there you might as well opt for that.
Dustin
Dustin
Car: 1987 Trans Am
Engine: LQ9/L92
Re: 2 or 3core?
what are your plans for future upgrades? you may not need to get the biggest rad out there if you're not planning on pushing things too much further. also, try out some water wetter; it does help lower temps down 5-10 degrees. when's the last time you changed your coolant?
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Re: 2 or 3core?
i might just throw some boost at the motor i got now, the coolant is new, just actally got it all together.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 2 or 3core?
If you are seeing the higher temps in town/redlights rather than on the highway, I'd say save the cash and try a lower temp fan switch.
Or, get a seperate adjustable fan controller. I use a Flex-a-lite controller, works really well - fully adjustable from 160 - 220 fan on temps, easy to wire, probes radiator instead of the head, has provisions for A/C, manual on/off switches and it starts the fan(s) at 65% of power so there's no huge amp draw on initial startup - a truly great product. Pricey at $100, but worth every penny - mine's been installed 4+ years now with no issues at all!
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Re: 2 or 3core?
my fan turns on with the key. there is a kill switch with the fan/fuel pump that i use so if any one trys to take my car is will only get about 10 feet.
Car: 1992 RS
Engine: Carbed 350
Re: 2 or 3core?
210 - 220 is average for these cars. Guage might be off as well if stock guage - not too many 3rd gens have accurate guages anymore after all these years.
But as mentioned - if it makes you happy, get the biggest rad that you can afford and that will fit - can never go wrong with better radiators right?
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Re: 2 or 3core?
true.. i was thinkin the 2 core just because it looks better in there then the single core plastic one.
atiroc1
23
Aug 20, 2008 12:27 AM
