What relays are these ??
Old Aug 28, 2013 | 08:42 PM
Stonehenge's Avatar
Car: 1989 5.7 IROC Dark Red/Blk 92Z28
Engine: 5.7
Transmission: 700R
Can someone tell me what relays these are ? 1989 IROC 5.7 TPI I always thought they were my cooling fan relays.. if you know their locations will someone enlighten me P L E A S E... frustrated
Stone
Old Aug 28, 2013 | 09:19 PM
Re: What relays are these ??
Unplug em and see what stops working.
Remember, it's not rocket science; just a car.
Old Aug 28, 2013 | 09:32 PM
Stonehenge's Avatar
Engine: 5.7
Transmission: 700R
I did, nothing happened... Stone
Old Aug 29, 2013 | 12:45 PM
topradman's Avatar
Car: 91 Z28
Engine: Super Charged 414 FI Roller Mtr.
Transmission: CK Perf. 4L80E Manual W/Transbrake
Axle/Gears: 9" Ford 3.25
Stone
Assuming you have dual fans, one is standard fan, other is 2ndary fan for HD cooling application, 3rd is fuel pump relay
Old Aug 29, 2013 | 01:04 PM
Stonehenge's Avatar
Engine: 5.7
Transmission: 700R
See, that's what I thought too.. but I ran the motor, waited for the fans to come on, then unplugged both relays and the fans still ran. Then I read somewhere else that the fan relays were over by the battery so I checked and found two relays there. I unplugged one at a time and the fans went off one at a time.. but the question remains.. yes the big one was the fuel pump because when I unplugged it the car shut off. I have dual fans
stone
Old Aug 29, 2013 | 06:20 PM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
They would be your MAF relays, at least thats where they are on my car.
Old Aug 29, 2013 | 08:38 PM
Stonehenge's Avatar
Engine: 5.7
Transmission: 700R
That makes sense since I got a check engine light ON when I unplugged them then went away when I plugged them back in... thanks for your answer
stone
Old Aug 29, 2013 | 11:22 PM
topradman's Avatar
Car: 91 Z28
stone
I'm really sorry about that answer. I try very hard not to pop off with bs just to have something to say like some seem to. My 91 indeed has 3 relays by my booster as yours are pictured and they do run the 2 fans and the fuel pump. Apologies.
Old Aug 30, 2013 | 10:33 AM
Stonehenge's Avatar
Engine: 5.7
Transmission: 700R
No apology needed, you took the time to answer and for that I'm grateful.. stone
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
