correct thread?
Old Jan 8, 2007 | 10:39 PM
91 camaro rs's Avatar
Car: 91 rs
Engine: 305tbi
Axle/Gears: 3.27 9bolt
correct thread?
i donno if this is the correct thread but what is really involved with tuning? it seems like every time u add a new part you have to tune your computer. i have a 91 camaro rs with a lo3 anyone give me a hand?
Old Jan 10, 2007 | 09:58 PM
AtomicTruck's Avatar
Car: Pro Stadium Tough Truck
Engine: Buick V6 272 cu in
Transmission: TH350
Axle/Gears: Broken most of the time
Your point is basically true for a carb machine also. New parts that hopefully add performance require different fuel and possibly timing, etc.
With an ecm it is a little bit easier. The reason is that you can get a datalog from the computer, which you can use to determine exactly what fuel adjustments to make. Timing adjustments are basically still the same though because the ecm doesn't tune timing... that's all up to you. However, there are enough experts in the place to answer about any question and even look at your bin...
Go to the DIY PROM board and read the stickies a few times to get a idea how it all works.
morrow
Jan 13, 2024 12:29 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
Jackrabbit501
Sep 2, 2015 09:14 PM
