Please Help how do I fix?
Old Mar 31, 2010 | 07:24 PM
87TPI-5SPD-TA's Avatar
At almost 41 years old I bought the T/A I wanted in high school. So I'm a car guy but I'm old school. So This TPI stuff is killing me. I'm trying to learn this stuff. What I have are 3 codes and a car that runs like crap. The codes I have are TPS LOW -TPS HIGH and MAF LOW. The guy I bought it from installed a new MAF and a NEW TPS. The plug for the TPS broke so he cut it off and installed a new one using butt connectors I have since soldered the connections and shrinktubed them. I have bought an ALDL cable and am using the Datamaster program retrieve the codes. I am not sure on what to look at first since both of these items are new. Could I possibly have a bad ECM? What should I look at first? PLEASE HELP.
Old Mar 31, 2010 | 09:13 PM
91Bonemaro's Avatar
Car: 91 Z28
Engine: 5.0 TPI
Re: Please Help how do I fix?
I would start by checking your TPS voltage, heres a link to a great guide on how its done.
http://www.iroczone.com/2009/10/adju...on-sensor-tps/
Old Apr 1, 2010 | 08:06 PM
ok checked and adjusted the TPS. I cleared the codes, the car doesn't want to idle until it warms up now.And I'm not showing any codes. After it warms up it idles but it surges still no SES light or codes. After running for about 15 minutes I shut the car off for about 2 minutes, then started it again now it doesn't want to idle but the car is warm. Any ideas
Old Apr 2, 2010 | 05:04 PM
91Bonemaro's Avatar
Car: 91 Z28
Engine: 5.0 TPI
Try cleaning the IAC and adjusting the idle. Heres links to that same site.
http://www.iroczone.com/2009/10/clea...rol-iac-valve/
http://www.iroczone.com/2009/10/adju...ir-idle-speed/
Old Apr 3, 2010 | 06:21 PM
How do you know if the IAC is bad? Had it out to clean it. Didn't make a difference.
Old Apr 3, 2010 | 07:23 PM
91Bonemaro's Avatar
Car: 91 Z28
Engine: 5.0 TPI
Im having a very similar issue but mine involves my speedometer too. When my IAC went bad there was no check engine light, the cars RPM's stayed at around 2500 in both drive and park and pretty much drove itself, without my foot on the pedal the car would go at least 25mph. Without the ECM setting codes its pretty hard to diagnose whats causing the problems and throwing parts at it can get expensive.
Old Apr 3, 2010 | 07:54 PM
when I had the IAC out I pushed and pulled on it a little not hard but want to see if it would move.It wouldn't and was solid as a rock. Should it move?
Old Apr 3, 2010 | 08:18 PM
Stephen's Avatar
Car: 87 GTA
Odd if you are getting no codes, yet running so rough.
I would pull the dizzy cap. Check the rotor & the cap itself. Both good?
Start with the basics. Start pulling pugs & check to see how clean they are/if they are gapped good, etc.
While your pulling plugs, I would start checking the plug wires themselves, seeing if every plug is actually firing good & on every stroke.
Old Apr 3, 2010 | 08:51 PM
Bought all that today. changed the cap and rotor still not right,will change plug and wires Sunday.
Old Apr 4, 2010 | 03:45 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
You should be able to pull or push on it with moderate force.
If it didn't move at all you should pull it off and get it freed up.
Old Apr 5, 2010 | 07:52 AM
The tune up is done, still no change. The IAC is out I've pushed and pulled and it doesn't move. So is it bad? and if it would move how far in and out should it move?
Bubbajones_ya
Oct 25, 2015 08:01 PM
Reid Fleming
Oct 10, 2015 09:56 PM
dusterbd
Sep 29, 2015 08:40 AM
z28joe2
Sep 28, 2015 05:54 PM
mfp189
Sep 27, 2015 09:25 AM
