86 Z28 carb PCM use with TunerProRT
Car: 98 Trans Am
Transmission: A4
HI guys,
My first new topic here, so I hope I am doing it right.
I am helping a programmer who is developing an Android app for the 160 and 8192 baud PCM's and have run into a little problem. In order to help, i bought a used PCM which supposedly came from an 86 Z28 carbed car. Unfortunately that is all the information I can find on it (painted on at that). I used WINALDL to scan it, but it required me to invert the signal and feed that into a regular TTL-to-Serial USB FTDI module (not RS232). The module works fine with a 94 Formula PCM so I know it works ok. That seemed strange to me that it needed to be inverted, but it did work ok with WINALDL. I would like to use TunerProRT to verify that is necessary but I cannot get it to connect. I am not even sure I am using the correct definition file (1227165_160.ads) for a carb engine. Does this sound like the correct file? Is there any way I can verify which PCM I have without a label attached? Am I wasting my time with this PCM?
Also, is it a quirk with WINALDL that inversion of the signal is a requirement, even when using a non-RS232 adapter?
Thanks for any help you can offer.
Car: check
Engine: check
Transmission: check
Re: 86 Z28 carb PCM use with TunerProRT
The carb ECMs use a lamp driver module that inverts the serial data.
The 1227165_160.ads definition file isn't the correct one, but may be close enough to work.
RBob.
RBob.
Car: 98 Trans Am
Transmission: A4
Aaaah. I saw the lamp driver in the service manual diagram, but wasn't aware it was inverting. So I guess the carb ECM is programmed to output an inverted signal instead of a normal one?
Is there a "correct" file to use for this ECM? Or would I have to make my own? Even when the signal is inverted, TunerPro will not connect using that file.
Car: 98 Trans Am
Transmission: A4
OK I will answer my own questions now:
"So I guess the carb ECM is programmed to output an inverted signal instead of a normal one?"
Yes
Probably not.
Probably, yes.
It connects now after changing the packet payload size from 25 to 20, which matches the ECM. Bad data, but now I just have to edit the value fields to fit the ECM.
Yes
Probably not.
Probably, yes.
NBrehm
08-25-2015 11:49 PM
GVMV
08-16-2015 08:01 PM
