Idle bump on L98 chip or no chip thing?
Old 03-19-2017, 10:37 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I just like a higher then stock idle on anything, car or bike that is "stick" is this a chip only option?
[ closer to the min take off speed, where you can be lazy on clutch/gas n not fart n die ]
Old 03-19-2017, 11:05 PM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Idle bump on L98 chip or no chip thing?
Target idle is in programming.
Old 03-20-2017, 06:25 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Like pringles, once ya start tweaking ya just can't stop...
900 idle, 180-190 fan kick on [ 180 stat ], vats disable, bump speed limiter to 300MPH just in case [ waiting on 228 for the stock temp range for the fan to kick on is nerve racking, cause what if it doesn't this time..... ]
Now DIY or just pay for it, hmmm whats a fair going price?
Old 03-24-2017, 03:33 PM
Engine: Lb9
Transmission: M20
$65 on up for reprogramming, or with a moates.net burn 2, a sst27c512 eeprom and g1 adapter for the diy. The speed limiter is maxed out at 200 mph .
But who needs a speed limiter with a turbine engine.
Old 03-25-2017, 02:36 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Haven't taken it over 70, might see 75-80 but that's about it. Didn't buy it to go fast just want to tweak a few things more to my liking. as its an oddity for most with the 4+3 trans.
you able to burn me one?
