Crank Fuel PW vs Bosch-III's
Interesting… I’ve been reading about cranking issues with Bosch-III injectors. While mine seemed to start ok with the factory ANHT settings and my Bosch-III's, I decided to play around with it a little to see what would happen.
What I found was that a 50% reduction in the Crank Fuel PW vs Coolant table generated a pretty good improvement (leaving everything else alone).
Given the higher flow at low PW's for these Bosch-III’s, it seems to make sense that reducing the crank fuel PW values would help (probably was getting too much fuel delivered during cranking).
Re: Crank Fuel PW vs Bosch-III's
Left ANHT. Right is my modified version... (basically just scaled the whole table down by 0.5)
BTW, what do you guys define as "long" crank times?
I mean, mine certainly isn't one click and "VROOOOM"....
When first starting up cold, it cranks for may be 1 to 2 seconds and then starts right up. To me that's pretty good... seems to match my daily driver and my wife's car. But I'm not sure what a factory fresh TPI Camaro is supposed to be...
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
My 89 with Bosch IIIs had a long crank time. 3-7s. I hated it. Tuned Performance made some changes to the stock 89 tune to compensate. Not sure if they were related to the IIIs or just the 89 PROM. Takes 2 revolutions of the engine or less to start now.
